Post hole digger / auger question
   / Post hole digger / auger question #1
coolbrze
VA
Kubota MX5800
A friend of mine has an auger / post hole digger for his 35hp tractor. Can I run it on my 60 Hp tractor or will that damage the auger since I'm assuming they're rated for different HPs?
   / Post hole digger / auger question #2
pretty sure they mean AT LEAST x HP when they note HP to make sure the tractor can handle it
   / Post hole digger / auger question #3
Worst that can happen is you break a shear pin, or get it stuck in the ground. Bring a big pipe wrench with a long extension in case you need to reverse it out.
Thanks fellas from the Old Dominion!
   / Post hole digger / auger question #5
Just remember, you don't need a lot of horse power for digging holes...I run mine (12" auger) just above idle and it does great. BobG in VA
   / Post hole digger / auger question #6
BobG is absolutely right. Keep your machine throttled down and go slow into the hole. I always start the hole with a hand post hole digger to keep the auger from wandering and to keep the holes reasonably in a straight line. After a few holes youll figure out what you should and shouldnt do.
   / Post hole digger / auger question #7
Yep, Bob is exactly right, slow and steady is the best method for digging holes with a PHD
   / Post hole digger / auger question #8
I'm not a fan of running my auger at idle. There isn't as much power in the hydraulics to lift it out and clean the hole. I'm at 1,200 to 1,500 when I drill my holes, and sometimes I will step on the gas pedal to get even more RPMS for additional hydraulic power when needed.
   / Post hole digger / auger question #9
Here's what I use to clean out my holes after I auger them. It doesn't seem to matter what RPM I run, the auger never completely clears the hole of all the loose stuff. I gave up on those crappy clamshell diggers years ago.
Boston Digger
   / Post hole digger / auger question #10
Great! Another tool I have to buy.
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
