Buying Advice Post hole auger for T1110 yes or no?
   / Post hole auger for T1110 yes or no? #1
brunswickboy
Moncton
NH T1110
Hi all
Has anyone used a T1110 with a posthole auger? I am thinking of getting one and was wondering if the frame on my machine would take it. The ground here in New Brunswick Canada has a lot of clay and loam.
Thanks
Brunswick Boy
T1110, loader, 60 inch rear mount mower, 48in bush hog, 6ft landscape rake, 50in tiller, 5 ft rear blade, 54in snowblower
   / Post hole auger for T1110 yes or no? #2
Just Bought a auger from Everythign attachments for my T1110 it shoudl work fine.
The rear lift is reated for something like 1000lbs.
I reguarly pull my boat around the yard with the little critter and that is around 5000 lbs...
Let you know tomorrow, the auger should be in today.
Thanks
I would appreciate it along with the model number please.
Jake
   / Post hole auger for T1110 yes or no? #4
web site.
ETA 6900HD Tractor 3 Point Hitch, PTO driven, Post Hole Digger, Post Hole Driller, Auger
I bought the 18 inch size and dug holes for 19 trees last weekend. Worked great! Beware of how you use it, dig a little clear the bit and dig some more. If you load up the bit too much you will play **** getting it out of the hole.
Make sure it is straight when you dig.
Other than that i have another 20 trees coming inthe next couple of weeks and I expect it will be just as fun.
Cheers
450 Gallon Fuel Tank With Pump (A46683)
450 Gallon Fuel...
2013 Dodge Grand Caravan SXT Minivan (A48082)
2013 Dodge Grand...
2014 Harvestec 6306 (A47164)
2014 Harvestec...
2014 Dodge Challenger SXT Coupe (A48082)
2014 Dodge...
Pair of Tractor Tires on Rims (A47164)
Pair of Tractor...
2014 KUBOTA R520ST WHEEL LOADER (A50458)
2014 KUBOTA R520ST...
