Buying Advice Post hole auger for T1110 yes or no?
   / Post hole auger for T1110 yes or no? #1
brunswickboy
Moncton
NH T1110
Hi all
Has anyone used a T1110 with a posthole auger? I am thinking of getting one and was wondering if the frame on my machine would take it. The ground here in New Brunswick Canada has a lot of clay and loam.
Thanks
Brunswick Boy
T1110, loader, 60 inch rear mount mower, 48in bush hog, 6ft landscape rake, 50in tiller, 5 ft rear blade, 54in snowblower
   / Post hole auger for T1110 yes or no? #2
Just Bought a auger from Everythign attachments for my T1110 it shoudl work fine.
The rear lift is reated for something like 1000lbs.
I reguarly pull my boat around the yard with the little critter and that is around 5000 lbs...
Let you know tomorrow, the auger should be in today.
Thanks
I would appreciate it along with the model number please.
Jake
   / Post hole auger for T1110 yes or no? #4
web site.
ETA 6900HD Tractor 3 Point Hitch, PTO driven, Post Hole Digger, Post Hole Driller, Auger
I bought the 18 inch size and dug holes for 19 trees last weekend. Worked great! Beware of how you use it, dig a little clear the bit and dig some more. If you load up the bit too much you will play **** getting it out of the hole.
Make sure it is straight when you dig.
Other than that i have another 20 trees coming inthe next couple of weeks and I expect it will be just as fun.
Cheers
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2022 J&M 1151-22S Classic Grain Storm Grain Cart (A50657)
2022 J&M 1151-22S...
Misc Machine Tools (A50860)
Misc Machine Tools...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
