Tractor Sizing Post driver
/ Post driver #1
SBorch
Redding
9N
What is the smallest Mahindra tractor that one could use a post driver on. I'm thinking Shaver 8d using it on front or rear. Takes 4 gpm flow at 1500psi. The 10d needs 12gpm @1500psi:rolleyes:
/ Post driver #2
You may want to look at a danuser driver, they use pto as opposed to remote hydraulics, just a thought, know it didn't answer the question, sorry...
Rich
/ Post driver
Thanks so much. Any help is appreciated.
/ Post driver #4
Any size tractor that can carry the drivers weight on the 3ph safely will do. That probably means a tractor weighing 2K pounds or more. The hyd delivery is not very important just so youve got at least 1500psi. That pressure is necessary to lift the ram reliably. Lower flow will just slow the lift a little. The driver works by only the fall of the ram driven by gravity, so lo flow will just limit your blows per minute not the force of the blows. Even idling my 2010 JD lifts the 8D ram in about 2 sec since the lift only consumes about 1 pint of fluid.
larry
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
2019 HYUNDAI V12530152-AJS DRY VAN (A59912)
2019 HYUNDAI...
2012 Toro Z Master Professional 72in Zero Turn Mower (A61572)
2012 Toro Z Master...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
KUBOTA SVL 75-2 SKID STEER (A64279)
KUBOTA SVL 75-2...
