Post driver return line inlet location
/ Post driver return line inlet location #1
Todd NE WY
North East WY
JD 4320
Hi all,
I am a long time reader but I think this is my first post. Yesterday I bought a Shaver post driver, the basic unit. It is used but I have been reading about them for quite awhile so I know I need to dump the return line directly into the return resevoir. I have a JD 4320 with the ehydo trans, where on the rear of the tractor would be the best spot to tie the return hose into the trasmission housing. The first thought would be a modified filler cap, right now it is the little plastic screw in one, where I could attach the return hose to an extension screwed into the same location.
Thanks in advance for the help.
Todd
/ Post driver return line inlet location #2
/ Post driver return line inlet location #3
The modified filler cap is the best way, just go to JD and get a "spare" that you can adapt a barbed fitting to-You can use a brass one from Home Cheapot because the pressure is low on the return.
Thanks guys. I had read the other thread and figured I was on the right track but just wanted to make sure.
Todd
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2020 INTERNATIONAL...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
NEW HOLLAND 1725 FORD TRACTOR (A65057)
NEW HOLLAND 1725...
CRATE OF MISC ELECTRICAL WIRING (A68842)
CRATE OF MISC...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
