Possibly the longest shop build in TBN history
   / Possibly the longest shop build in TBN history
   / Possibly the longest shop build in TBN history #62
Looks great!!!!
Here’s some “doodles” while I’m drinking coffee
   / Possibly the longest shop build in TBN history #63
look at the circled area.
This manufacturer uses a piece of tube steel for the pivot.
This door weighs approx 2000 pounds.
   / Possibly the longest shop build in TBN history #67
This looks like it would work good. I have a buddy who is bringing me some baler belts tomorrow. If they don't work, I'll definitely look at ordering this. Thanks
I wasn’t sure what the transition looked like at the top frame/hinge/door interface looked like.
I figured a couple different products could help get your gears turning!
Depending on what controller/valve assembly you use I know the hydraulics like to have something to “stop” against. Most manufacturers use an adjustable pressure valve body with a solenoid that turns off the pump when a certain pressure is reached……….of course stop pushing the button can work as well ;)
I'll try to get better pics this evening if I can before dark. I'm hoping to get someone to help me wire in some solenoids, I hope I bought the correct valve. I know that my son will use it some and it would be easier for the solenoid to stop it than him have to gauge when to stop.
I haven’t forgotten about pics of gasket area, just got busy with family and really need to open door fully to show what I need. I did get it all set up and found a few issues that I need to fix. I already turned the cylinders around, don’t know where my head was. Ordered another flow divider for the close function as it wanted to twist door with just a T.
Here is a wick pic. This is before I turned cylinders around. Everything is temporary mounted until I get wall finished.
2008 Genie S-65 65ft Telescoping Boom Lift (A55787)
2008 Genie S-65...
2018 KENWORTH T880 DAYCAB (A55745)
2018 KENWORTH T880...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
2019 VOLVO VNR TANDEM AXLE MID ROOF TRUCK (A56129)
2019 VOLVO VNR...
2013 MACK GU (GRANITE) TRI AXLE WINCH TRUCK (A55745)
2013 MACK GU...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
