finn1
Platinum Member
- Joined
- May 10, 2009
- Messages
- 899
- Location
- Upper Michigan, Marana Az.
- Tractor
- Kioti CK4010 hst, Cab, Deere 26G excavator, K1500 w/ Boss 7’6” plow, F450 dump W/ Boss 10’ straight blade Super Duty plow, F250 reg cab, F350 cc drw, Case TR310 CTL
There痴 a similar threat that was brought back from the dead, but most of the posts are sixteen years old, and technology has come a long way in that time.
Anyway, to get to the point, I traded in my 2004 Deere 240 Series ll skid steer when I bought my Kioti CK 4010 SE cab tractor almost two years ago. I have come to realize that a compact tractor is in no way a replacement for a piece of construction machinery. The tractor handles snow removal well, but lacks when doing loader or fork work because it is too light and forward visibility is poor compared to the skid steer.
Our property is on the lake, and my current project involves adding a lot of drain tile, including trenching with my mini excavator, and adding 2a rock under and over the tile. I pit a couple hundred feet in last year, and the 4wd tractor was marginal at best in the wet, sloppy conditions.
I determined that I will purchase a CTL for this and other general use projects. Eventually I may pick up a hydraulic snowblower to replace the tractor. Renting will cost about $1500/ week, but I am retired and don稚 want to deal with schedules. It may take all summer to complete this project.
I priced out both the Deere 317g and 325 G machines, and almost pulled the trigger on the 325G, but on the spur of the moment called the Case dealer. He quoted on a TR310, for only about $2000 more than the Deere 317G, and considerably less than the 325G.
On paper, the Case is a much more robust machine than the 317G. More power, wider tracks, more lift, lower ground pressure (as quoted), ore hydraulic flow(Case std flow.
Everything quoted is cab, a/c, iso, air seat, cold start kit, etc.
My quandary is that I have no experience with Case, and have 10 years of excellent service from my old Deere.
Any suggestions or recommendations? Anyone have experience with the newer Case machines? Not really interested in info on older machines, as I don稚 think that痴 relevant.
Same questions about the newer Deere products.
Other makes aren稚 really in the running. No Kubota dealers, not interested in Bobcat, and the Cat dealer is too big to get any personal attention.
I have good experience with my mini ex purchase, and was impressed with the Case Sales person.
