Possible hydraulic cylinder problem.
/ Possible hydraulic cylinder problem. #1
TerryinMD
Veteran Member
Sharpsburg, Md
John Deere 4100 HST
I bought a 54" front blade for my JD 4100 at an auction to try to save some money, but it has turned on to be a bit of a nightmare.
I talked about it in a post under attachments and this project has taken a life of it's own.
I got all of the important parts and modified some others to make it "work" but now that I have it all together another problem has reared it's ugly head.
It appears as though I have one of two possibilities. A bad cylinder or one that is incorrect for the application. Let me explain.
The angling cylinder is working just like it should - moves the blade left and right. The lift cylinder only pushes the blade down!! /forums/images/graemlins/mad.gif I cannot lift the blade off of the ground. I've switched the hoses to reverse the fluid flow and that has not helped. The cylinder is installed correctly and cannot be reversed. Another interesting issue is that one of the new quick connect male connects does not seem to work properly. However, once the lines are connected I would think that the fluid is flowing as it should. I've cycled the cylinders a few times to purge the air. And I also placed a floor jack under the blade's frame to force the cylinder in the lift position hoping that any trapped air may be forced out.
Anyway, I'm at a loss as to figuring this out. Oh yes, I've looked up the parts under JDParts and they do not have any specifications for the cylinder using the current part number.
Any ideas???? /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
Terry
/ Possible hydraulic cylinder problem. #2
When you try to lift the blade, does the tractor sound like it is trying? Is it goeing into relif mode?
Is the QD you sppek of on the lift circuit?
Kennyd,
Yes, the tractor is definitely trying to lift the blade. The cylinder moves slightly but does not lift the blade and the quick connects are color coded to the correct connections. JDParts helped on that part.
Terry
/ Possible hydraulic cylinder problem. #4
Is there enough hose to swap angle and lift circuits? Try to eliminate cylinder trajectory problems and prove that it works with angle circuit. There's a thread here somewhere about 3way and 4way circuits for Kubota's loader valve that could be similar to the JD's.
Hmmm... didn't think about this one.
I'll give it some time before trying this one - it's snowed a bit and I prefer to stay inside where it's warm!!! /forums/images/graemlins/tongue.gif I'll get a few a more suggestions before venturing out into the wintery mix. That way I'll maximize my time outside. Hey, what the heck - at least we getting a little wiser when we get a little older. /forums/images/graemlins/wink.gif
Terry
/ Possible hydraulic cylinder problem. #6
You said the angle works fine. This is with the left/right movement of the joystick correct?
IF by chance it is up/down that is working the angle, then the REGEN on the joystick is probably your problem.
When you tried to lift the blade with the jack, what happened? Try do do this with on end of the lift cylinder disconnected to make sure the frame is not hitting anything...
/ Possible hydraulic cylinder problem. #7
BTW, The dump/curl circuit (and angle for your blade: left and right on the joystick) should be the yellow and silver QD's.
Like I mentioned earlier, I've set up the quick disconnects based upon the JDParts diagrams. Checked and rechecked. The angle movement is correct. Works flawlessly!!! Just the danged lift that is not correct.
Does anyone have a JD 54" front blade on their 4100, 4110, etc. I do not have an operators manual so I'm shooting from the hip. Angle movement is done by moving the joystick left to right. No problem. How about lifting the blade and lowering it. Pull back on the joystick and the blade is lifted out of the way. Correct!! Push the joystick forward and the blade is lowered. Correct!! If you slap the joystick forward in detent, the blade should float. Correct!!
Terry
/ Possible hydraulic cylinder problem. #9
sound a lot like you have the lift circuit set up to the wrong side of a valve. I did the same thing when I installed my blower - it would go down not up. In my case I had to bleed the circuit to get the quick connet off.
if the angle works fine, I'd be tempted to reverse the circuit.
/ Possible hydraulic cylinder problem. #10
Well, You have all the movements correct....not sure what the problem is. I take it you do not have a FEL and never used the DSCV?
The Manual for the 4110 is avialable in PDF format on www.johndeere.com somewhere...It is pretty much the same as the 4100
/ Possible hydraulic cylinder problem. #11
</font><font color="blue" class="small">( The Manual for the 4110 is avialable in PDF format on www.johndeere.com somewhere...It is pretty much the same as the 4100 )</font>
Maybe he meant the manual for the blade?
/ Possible hydraulic cylinder problem. #12
What you are describing sounds like a check valve in the circuit. Is that a possibility? Your description sounds very much like either a check valve or one of your quick connects not seating properly. I'd be tempted to take the hose off to the lower side of the cylinder and remove the quick connect and put the end in a bucket. Then try to lift the blade. If it lifts and fluid flows into the bucket, you know your problem is the quick connect or somewhere in your control valve.
...my $0.02 worth.
All,
Thank you for the replies. I'm off tomorrow and will play around with the blade a bit. I'm going to stop by a Deere dealer and ask some stupid questions and pick up some replacement quick connects. I think one is faulty and it bothers me to no end that it might be DOA.
Let's hope that I do not get some stupid answers.
Terry
/ Possible hydraulic cylinder problem. #14
Going from memory, but what about the Dual Selective Control Valve (SCV) Lock Lever ? Is it in the right position? Seems that it does funny things depending on which position it's in.
Yep, the DSCV lever is in the unlocked position. One of the first things I checked.
Terry
Fini!!!! /forums/images/graemlins/cool.gif
End of problem!!! /forums/images/graemlins/laugh.gif
I visited my JD dealer and talked to one of the tech guys and explained my problem. Remember that I mentioned a malfunctioning quick disconnect. He said that the malfuntioning quick connect was probably the root of the problem. So, I picked up two of them (always like to have a spare) and replaced the bad one a short time ago.
Fired up the tractor and voila!!! The blade goes up and down and back and forth just like it's supposed to. And, since the bad quick disconnect is brandy-new, it is under warrenty and I get a credit for it. Bonus /forums/images/graemlins/cool.gif
Thank you's to everyone that provided a suggestion.
Terry
/ Possible hydraulic cylinder problem. #17
</font><font color="blue" class="small">( Fini!!!! End of problem!!!
)</font>
Great news, Terry. Now how about a couple of pictures of that blade in action? /forums/images/graemlins/cool.gif
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2016 FORD F-250 (INOPERABLE) (A60736)
2016 FORD F-250...
207272 (A52708)
207272 (A52708)
