Positive ground
   / Positive ground #1
KRB
Ford 3000
I'm having generator trouble on my 63 JD 1010 diesel. Was thinking replacing it with a alternator but not sure how to hook it for the positive ground system. Any help would be appreciated
   / Positive ground #2
If you are going to use an alternator you will need to convert to negative ground.
All you really have to do is switch you battery cables, and install the alternator. If you have an ammeter you will need to switch the wires on it or it will read backwards.
Your starter and lights don't care what polarity the ground is, the will work OK.
Stan
   / Positive ground #4
   / Positive ground #5
Many of the old 6 volt Fords have been converted to 12 volt. I believe, they were positive ground. My NAA had been converted before I got it. However, the voltage reg. or generator quit, so I installed a one wire, 12 volt alternator on it. No regulator needed.
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2003 KOBELCO SK235SRLC EXCAVATOR (A54607)
2003 KOBELCO...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
