Positive ground
   / Positive ground #1
KRB
Ford 3000
I'm having generator trouble on my 63 JD 1010 diesel. Was thinking replacing it with a alternator but not sure how to hook it for the positive ground system. Any help would be appreciated
   / Positive ground #2
If you are going to use an alternator you will need to convert to negative ground.
All you really have to do is switch you battery cables, and install the alternator. If you have an ammeter you will need to switch the wires on it or it will read backwards.
Your starter and lights don't care what polarity the ground is, the will work OK.
Stan
   / Positive ground #4
   / Positive ground #5
Many of the old 6 volt Fords have been converted to 12 volt. I believe, they were positive ground. My NAA had been converted before I got it. However, the voltage reg. or generator quit, so I installed a one wire, 12 volt alternator on it. No regulator needed.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
434669 (A48836)
434669 (A48836)
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
