Position of bucket when parked?
   / Position of bucket when parked? #11
Agreed, if only temporarily outside for short periods of time, overnight here and there then I'd not worry either way.
I worry when outside for a couple of nights and if it is raining.
These machines are too expensive to just let sit out and rot, even just a tarp makes a huge difference.
I'll be laying a layer of crushed stone this year so my trailers are no just sitting on the ground, long run I'd like to pave a spot out back for them to sit on.
Joel
   / Position of bucket when parked? #12
I agree with the fluid film comment. I park inside but the BH can sit for long periods in the corner of the barn so I always make sure the exposed cylinders, or any other part I worry about gets sprayed with FF.
   / Position of bucket when parked? #13
I do what the others do and leave the bucket curled in resting on a 4x4 to keep it off the ground. The one thing I was told is after turning the engine off was to push the control through all the positions to release any pressure in the lines. You'll hear a little pressure release and the bucket will only move a tiny amount.
Years ago when I got my first tractor with FEL I was told the same thing - to push the control through all the positions to release any pressure in the lines and you do hear the pressure release. I always leave the bucket curled and all the way down and relieve all the pressure in the lines.
   / Position of bucket when parked? #14
It is relatively cheap and easy to replace a rusted through bucket if it ever actually rusts through. Hydro clyinders aren't so cheap. As such, I vote for a bucket of water vs. rusty rods.
My Kioti currently sits outside while the barn is occupied with junk during our remodel. It makes me cry sometimes.
   / Position of bucket when parked? #15
Bucket Paint - EZ Slide paint from Tractor Supply put on the inside of the bucket replaces the flaked/scratched off paint and is pretty good about keeping the mud from sticking. Position of the bucket. I store min in the barn during bad wx but outside I put the bucket down far enough to drain water and act as a parking brake (my dealer does this also). Now, aside, an old tractor driver told me that the only good parking brake is a good tree. I believe it and practice it anytime Im on a hill or around the pond.
I've parked the tractor back in its home so no more unsheltered nights. The spring will be a good time to touch up/repaint the loader. I think I take better care of the tractor than I do my daily driver!
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
Kubota RTV-X900 Utility Cart (A56857)
Kubota RTV-X900...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 TAKEUCHI TL12V2 SKID STEER (A52709)
2019 TAKEUCHI...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
