Position Control - Versus Draft Control
/ Position Control - Versus Draft Control #1
RamTruckMan
Does Position Control mean that a tractor doesn't have any draft control? Does it mean the lever just lowers and raises the implement?
/ Position Control - Versus Draft Control #2
Position control means that you can lift the 3pt hitch to where you want it all through the spectum of it's travel and it will stay where you set it. It does not aim the implement for drafting at all. The position control usually has a set of numbers so you can index each implement and "supposedly" get that same setting each time by returning the position control to the number you have chosen. John
Thanks for the prompt response, isn't that a step back in technology. If I were plowing wouldn't the plow have a tendency to cut too deep or ride or top of the ground depending on roughness of the terrain?
/ Position Control - Versus Draft Control #4
You know, I can't really respond to that as I have yet to do any plowing with my CK20HST with position control, no draft control, but I think you're probably right. The hitch arms can come up and float so I guess without draft, the implement may not continue to dig at the depth you wish. I'm just now learning about using the plows/disks/etc for this tractor. I've used draft control in the past. John
/ Position Control - Versus Draft Control #5
RamTruckMan, I just went searching for better information, and I think you'll be surprised to read the "draft" position part as it seems to work a little differently than we both thought. Check out this link, it's a good article covering several hitch types. http://www.tractorsmart.com/enter.htm John
/ Position Control - Versus Draft Control #6
RamTruckMan, I just went searching for better information, and I think you'll be surprised to read the "draft" position part as it seems to work a little differently than we both thought. Check out this link, it's a good article covering several hitch types. John 3pt hitch types
Thanks for the link. That site is very informative. I used to have that link, but it must have gotten lost in upgrading. I looked all over for it before I posted a message.
Thanks again.
/ Position Control - Versus Draft Control #8
You're welcome, and go to "my home" and check for the private message I sent you. John
/ Position Control - Versus Draft Control #9
No feed-back control would be like the typical front-loader circuit. You open the valve to make it move, and close the valve to hold it in place. Repeatability is up to the operator to judge the position. Things like leak-down tend to make the positon slowly change with time.
Position control has an active valve that maintains the draft arms in a set position according to a control, often marked with arbitrary, but at least somewhat repeatible settings. It will automatically adjust the rockshaft to the set position and hold it there (gravity doing the holding in the down direction).
Position control is useful for things like grading with a blade or landscape rake where you want to have the blade at a set height in relation to the tractor wheels and you are trying to create a level or smooth surface.
Draft control has the feedback valve connected to the top link. It senses how hard the plow is pushing forward on the top link. The deeper the plow is digging, the more it trys to pivot the hitch forward, pushing forward on the top link. The control valve would then raise the plow a bit maintianing a constant force on the top link. If the force is too low, the control valve lowers the plow a bit, causing it to dig deeper and increase the force on the top link to the desired set-point.
Maintaining a constant plowing drag should correspond roughly with a constant plowing depth regardless of the lumpiness of the ground. So when your front wheels go in a little dip or over a lump, or the plow runs over a dip or a low spot, the lift arms get adjusted to maintain the same plowing drag force and thus the same plowing depth.
One is not "better" than the other, but If you are serious about plowing, you will want Draft control. Most CUT's are not used for serious plowingg and for most of their comon uses, Position Control is what you probably want.
- Rick
/ Position Control - Versus Draft Control #10
Draft control is a option of position control and you can't have draft without the position. The Draft control when used is how you would set your depth not with the position control. There has been much abuse of the system but it works great when it is used on a quality piece of equipment. One of the reasons I point this out as some manufacturers reponse load is at 20 percent vs less then five percent to signal a load change. Another point is the amount of signals the system can send. Some can work three times a second on the sensitive side and on the other end it might take three seconds.
/ Position Control - Versus Draft Control #11
Art, what about the 9N and 2N? They had draft control but no position control. Position control wasn't introduced untill the 8N or after draft control was out for at least 9 years.
Draft control = constant load on the tractor.
Position control = constant height of implement.
/ Position Control - Versus Draft Control #12
</font><font color="blue" class="small">( Art, what about the 9N and 2N? They had draft control but no position control. )</font>
That's true Charlie, but I don't know of a single "modern" tractor with draft control only. It's also important to note that draft control only works on "tillable" soil. If it's hard-packed, you aren't going to get the plow down into the dirt. Draft control will actively lift a plow, but it's up to the plow to get itself into the ground unless you have a larger tractor with down-pressure on the 3PH.
/ Position Control - Versus Draft Control #13
But who builds a tractor today with down pressure? Could be right on the old Fords, that might answer part of my frustration with trying to work them.
/ Position Control - Versus Draft Control #14
</font><font color="blue" class="small">( that might answer part of my frustration with trying to work them. )</font>
When I was a little kid (and dinasaurs roamed the earth) my father used to talk about a fellow he knew who was used to position control and borrowed someone's tractor with draft control. Evidently the guy was hooking up an implement and trying to get the 3PH to lift slightly like position control. He thought something was wrong and climbed up on the implement where he could reach the 3PH control, and kept slowly raising the control handle. All of a sudden he got the lift to operate when the control was high enough. Up came the implement all the way to the top while trapping and crushing his lower right foot and leg between the fender and the implement. /forums/images/graemlins/shocked.gif
That's a cruel lesson in how the draft control works on those old Fords. I have a selector handle on my old Ford Jubilee for position or draft control, but I just leave it in position control all the time.
/ Position Control - Versus Draft Control #15
You guys are right on - the 9n and 2n only have draft control, which means when working with an implement it is all the way up, or all the way down. Makes attachment fun /forums/images/graemlins/smile.gif
Of course when plowing soil, the feedback piston constanly moves the lift up and down with the drag of the soil, but the rest of the time it is a pain. There are aftermarket devices to override the draft control btw.
Bottom line - most compacts have position control, some like the BX and B7500 do not have true position control, since the lever is spring loaded and simply returns to the center setting at all times. This makes it harder to raise an implement like a brush hog, and return it to the exact setting as before. Also a bit trickier box blading. I have personally owned all types, and have adapted accordingly. Any hydraulics is better than nothing /forums/images/graemlins/smile.gif
1994 Hyster H80XL 8,800lb Straight Mast Diesel Forklift (A66734)
1994 Hyster H80XL...
2011 FORD CROWN VICTORIA POLICE CAR (A66091)
2011 FORD CROWN...
2008 Ford F-350 King Ranch 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-350...
1999 Freightliner FL112 Tri-Axle Dump Truck (A66736)
1999 Freightliner...
2016 CARGO CRAFT 16 FOOT ENCLOSED TRAILER (A67714)
2016 CARGO CRAFT...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
