Position Control Dial on T700
/ Position Control Dial on T700 #1
dcgrosvold
NW Arkansas
Montana T7074
Anyone else have a T700? I have a Montana-badged T700 that has a "position control dial" (their words) that controls the raising and lowering of the 3-point hitch. I have had trouble with it from day one. When I try to run it, it slips past the stops and keeps going in either direction. I've removed the cap and tightened the lock nut on the shaft, but no matter how tight I try to make it, one or two turns and it goes right back to slipping. It appears to be one of the cheap lock nuts with a nylon center.
Anyone else have this problem? If so, is it as simple as putting a better lock nut on it?
Thanks!
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2000 Hino (A64194)
2000 Hino (A64194)
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
