position control and MMM adjustment
/ position control and MMM adjustment #1
Massachusetts
Kubota B2910 w Curtis Cab & Kubota BX1500
I just got a new B2910 (trading in a B7500 that I have owned for a couple of years). I notice that the rear 3-point hitch is all the way down when the position control lever is only down to #2, rather than all the way to the bottom of the scale. Does this sound right, and does anyone know how to adjust the position control so that the 3-point hitch bottoms out at the same point as the control lever hits the bottom of the scale? May well be spelled out in the owner's manual and I would admit that I haven't had a chance to read it yet.
On a related point, I also notice that my MMM goes from the fully down on the ground to the fully lifted up under the tractor position by moving the position control lever only between ## 8 and 9 on the position control scale. I'm guessing that this can probably be adjusted somewhat by making some sort of adjustment to the 3-point hitch arms. Does this situation sound right, and any suggestions regarding adjustments are very much appreciated. What I am thinking (based on the way the height of my MMM was controlled by the 3-point hitch lever on my B7500) is that I would prefer to have the new MMM on my B2910 be lifted and lowered over a larger portion of the position control scale (say, between ##6 and 9, or between ##7 and 9).
Any words of wisdom much appreciated! Peter
/ position control and MMM adjustment #2
Peter
Here are a couple of threads on the Position control for a B 27-2910 tractor.
Position Control Range
Position Control Range Update
This is an old thread. Took me some time to find the 2 threads. I happened to see a thread about the MMM adjustments while doing a search for Position Control. But did not save it. /forums/images/graemlins/tongue.gif
You’re readings a close to my 2910. /forums/images/graemlins/smile.gif
/ position control and MMM adjustment #3
Sounds about normal. J
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
(2) Bell 500 Gal Saddle Tanks (A64119)
(2) Bell 500 Gal...
2015 Ford Transit 350 4x4 Sewer Viewer Van (A61573)
2015 Ford Transit...
Caterpillar Service Magazines from 1990's (A63117)
Caterpillar...
JOHN DEERE 437E LOG LOADER (A64276)
JOHN DEERE 437E...
