Posi-Lock wire connectors
/ Posi-Lock wire connectors #1
MChalkley
Elite Member
Eastern Virginia
EarthForce EF-5 mini-TLB (2001)
The discussion Gordon and I were having about electrical connections reminded me of a product that I really like for making electrical connections, especially ones that you think you might have to remove for some reason sometime later.
They're called Posi-lock connectors, manufacturered by a company called Swenco. They've got a web site at http://www.posi-lock.com, which shows the connectors and how they work. Also, you can buy them at http://thejeep.com/posi-lock/, as well as NAPA and Car Quest stores. A product they make that I've seen at a local Car Quest but not on the web sites is a rubber boot that absolutely waterproofs the connection. They're pretty good by themselves, but with the boots they're awesome.
Mark
/ Posi-Lock wire connectors #2
I've never used them they look like a very simple and well made setup. Will have to check into them but I have more crimp connectors than a little bit. Before I pulled the page up I thought you were going to show a bullet connector.
Gordon
Sometimes I start out using them to "rough in" a wiring project, figuring I'll use crimp connectors later, but they work at least as well as crimp connectors, plus are removeable and reusable. So, usually, they just stay there. They're certainly a lot easier to use than crimp connectors.
Mark
/ Posi-Lock wire connectors #4
Looks pretty interesting. I have heard about them but never tried them. I will give them a try. I usually strip the wire and the twist it into a union and solder it them heat shrink it. Very time consuming, but when it is done I know it will last a while.I do this for my wiring connector exposed to the out side elements. Here in northern VT the use an ton of salt in the winter so everything gets rusty and corrosion. I'll have to pick some up and give it a try.
Rowski - Well, nothing will beat your method, of course, but if you want to be able to have a good connection without a lot of time or special tools, they're the way to go. I always keep an assortment of them in every vehicle I've got.
I meant to ask you in the other post: What tractor did you order?
Mark
/ Posi-Lock wire connectors #6
Looks interesting. I've used every type it seems like and some are better than others. In addition to a good working connector, I use the "De-ox" or NAPA silicone for wiring to keep the corrosion at bay. It is what the major car makers are using in lamp bases and the like. A little dab will do ya!
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
Hawgee - I've been pleased with the results of de-ox, too and use it regularly. It works.
Another thing I found out today about the Posi-lock connectors is that they have spade and ring terminal connectors that connect to one end of it, so you can use it as a reusable connection to a device that requires the terminals. Cool.
Mark
/ Posi-Lock wire connectors #8
Marine grease, DE OX or any other product along that line is very smart and it does help very much in stopping corrosion. I can't argue the best connector is a soldered joint with heat shrink but at work thats impossible so crimp connectors are the way we go. But we still use alot of heat shrink and silicone grease.
One major thing alot of people overlook is the ground wire. They will have a heavy positive wire and a tstat wire for a ground. That is were alot of problems also start and are overlooked while troubleshooting it the ground wire.
Gordon
/ Posi-Lock wire connectors #9
Gordon, I was just getting ready to say something about the ground wire (or ground side). I see it often that someone does a good job on the power (or wire side) but forgets to properly clean, tight, and sealed gound connection (chassis or ground side) and has all these weird electrial problems.
/ Posi-Lock wire connectors #10
Mark, I'm getting (dad and I)are getting a NH 2120 gear.
-7309 loader with 72" bucket
-759c hoe with 24" bucket
-Curtis hard side cab with heater, wipres, lights
-Valby chipper single roller hydrualic feed
-rear blade 84" not sure of make yet
I'm sure I will have to do some explaining to do... why I went with what I did!!!!
Gordon - I think that's because most people don't realize that every amp on the hot wire is on the ground wire. If I'm trouble-shooting somebody else's stuff, I always look at the gounds first.
Mark
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
