portal axle oil?
/ portal axle oil? #1
YukonKing
Bronze Member
Whitehorse Yukon Canada
2021 L2501 FEL
will the oil from the axle housing run into the portal? this is after removing to change a short axle/hub
thanks
/ portal axle oil? #3
Yes it will. Fill it through the access hole on top of the axle and fill it enough to where the fluid is just visible at the top of the axle.
/ portal axle oil?
Thanks for the confirmation. I wasn't sure, i had taken all apart with the axle at an angle thinking that the whole thing would drain out...glad i did that.
/ portal axle oil? #5
Fill it up and run the tractor around a little then check it. It takes a while for the fluid to level out.
Sent from my Samsung SPH-L710 using TractorByNet
KBH Tank Trailer (A61307)
KBH Tank Trailer...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2016 Yanmar Vio25 (A60462)
2016 Yanmar Vio25...
208316 (A58375)
208316 (A58375)
