Portable sprayers?
/ Portable sprayers? #1
Jason280
Ga
Kubota L4330
Local yard has this parked on top of a pop up camper, and is willing to sell reasonably cheap. I thought it was one of those portable pressure washer setups, but looking at the pump, I'm curious if its just a sprayer setup for farms. Anyone familiar with these have any ideas? Supposedly, the Kawasaki 5.5hp just needs a new carb, but I am not too worried about the motor...I have a few extra Hondas I could use. I'm mainly curious about the pump, and whether its a true pressure washer pump or just a farm style sprayer.
/ Portable sprayers? #2
HyPro D30 is no pressure washer, sounds like a nice sprayer pump
9.5 GPM and a maximum pressure of 580 PSI
Gas Pressure Washers are up in the 2500-4500 PSI range and beyond
/ Portable sprayers? #3
Lesco is a big name in agricultural sprayers so parts should be easy to find. There are a lot of parts on that spray rig that when new are a lot of money, so if it mostly works and is not much money, it should be a good deal.
What type hose do these setups use?
/ Portable sprayers? #5
We had a couple of those set ups at work. Termite control, injecting chemicals into the soil around the base of a house. I've seen them used in Lawn care, spraying herbicides or fertilizers on to yards...
Hose would be any chemically resistant braided line that could hold couple hundred pounds of pressure.
There were several pumps that had gone bad in the junk pile... if they were not winterized, the crack and break.
Would be a neat project to turn it into a fire hose setup!!!
/ Portable sprayers? #6
Looks like a pest control setup for the back of a pickup.
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
