Portable generators to stay away from?
   / Portable generators to stay away from?
As the desired generator would get limited use, even in a power outage only a few hours a day, I can see no need to research getting an inverter. Can understand if perhaps this way for whole house and for many hours a day.
   / Portable generators to stay away from? #12
Be apprised that standby generators have went WAY up in price. A 17KW Generac will set you back around 15 grand installed.
   / Portable generators to stay away from? #13
Some say these small generators will run their whole house but they have a gas stove, gas water heaters, gas heat and the only items that are electric are lights, refrigerator maybe a freezer and the latter two don't run all the time. Now try a small generator on an all electric home and see what happens
willy
   / Portable generators to stay away from? #14
willy
My well pump alone is 2hp...
Whole house is electric to boot
   / Portable generators to stay away from? #15
Anytime we have an outage I select a time to get the water heater charged. Leave the fridge on all time Careful to not trip out coooking. I am even careful with the coffee maker. I only have a 6500 generator. But it’s a lifesaver
   / Portable generators to stay away from? #17
Wow, I think mine was around $6000 all in back in 2012. Helps to have a buddy that’s an electrician.
   / Portable generators to stay away from? #18
A generator puts out 120 VAC at 60 cps the sign wave is dependent on a governor to keep it and the voltage in specs. Some units put out a sort of crappy sine wave but it is a true sine wave and should not harm electrical equipment.
An inverter takes DC and turns into AC.
There are 2 types of DC inverters a pure 60 cps sine wave electronically converted from a DC source and a modified sine wave electronically converted usually from a battery.
The difference is cost a modified (MSD)inverter puts out a square wave while a inverter ( i ) puts out a highly regulated 60cps sine wave.
MSD is much cheaper to produce, can damage sensitive electronic equipment like TV's and computers and in some cases damage things like refrigerators.
   / Portable generators to stay away from? #19
computers can give 2 sh*t's about MSW. they are switching psu's and 90% of ups's used on them use MSW.
people like to say they damage crap, they really don't. UPS's and clocks and heat blankets tend to give a crap thats about it. maybe some high end furnaces.
no inverter generator I am aware of runs MSW.
   / Portable generators to stay away from? #20
Racer4. I was referring to watts. Sorry I did not specify
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
