Portable generators to stay away from?
   / Portable generators to stay away from?
As the desired generator would get limited use, even in a power outage only a few hours a day, I can see no need to research getting an inverter. Can understand if perhaps this way for whole house and for many hours a day.
   / Portable generators to stay away from? #12
Be apprised that standby generators have went WAY up in price. A 17KW Generac will set you back around 15 grand installed.
   / Portable generators to stay away from? #13
Some say these small generators will run their whole house but they have a gas stove, gas water heaters, gas heat and the only items that are electric are lights, refrigerator maybe a freezer and the latter two don't run all the time. Now try a small generator on an all electric home and see what happens
willy
   / Portable generators to stay away from? #14
willy
My well pump alone is 2hp...
Whole house is electric to boot
   / Portable generators to stay away from? #15
Anytime we have an outage I select a time to get the water heater charged. Leave the fridge on all time Careful to not trip out coooking. I am even careful with the coffee maker. I only have a 6500 generator. But it’s a lifesaver
   / Portable generators to stay away from? #17
Wow, I think mine was around $6000 all in back in 2012. Helps to have a buddy that’s an electrician.
   / Portable generators to stay away from? #18
A generator puts out 120 VAC at 60 cps the sign wave is dependent on a governor to keep it and the voltage in specs. Some units put out a sort of crappy sine wave but it is a true sine wave and should not harm electrical equipment.
An inverter takes DC and turns into AC.
There are 2 types of DC inverters a pure 60 cps sine wave electronically converted from a DC source and a modified sine wave electronically converted usually from a battery.
The difference is cost a modified (MSD)inverter puts out a square wave while a inverter ( i ) puts out a highly regulated 60cps sine wave.
MSD is much cheaper to produce, can damage sensitive electronic equipment like TV's and computers and in some cases damage things like refrigerators.
   / Portable generators to stay away from? #19
computers can give 2 sh*t's about MSW. they are switching psu's and 90% of ups's used on them use MSW.
people like to say they damage crap, they really don't. UPS's and clocks and heat blankets tend to give a crap thats about it. maybe some high end furnaces.
no inverter generator I am aware of runs MSW.
   / Portable generators to stay away from? #20
Racer4. I was referring to watts. Sorry I did not specify
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2007 JLG 660SJ TELESCOPIC BOOM LIFT (A52709)
2007 JLG 660SJ...
2022 BOBCAT E60 R2-SERIES EXCAVATOR (A52709)
2022 BOBCAT E60...
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
Frontier 3 Point 8' Disk Harrow, S/N 1XFDH13XVK002234, 22" Disks, Asset# 64 (A59076)
Frontier 3 Point...
2006 Dodge Ram Pickup Pickup Truck, VIN # 3D7KS28C66G203434 (A57453)
2006 Dodge Ram...
