Portable Diesel Generator Recommendations?
/ Portable Diesel Generator Recommendations? #61
I did the diesel, gas, propane, PTO debate with myself for a while. I was out of town half the time and there was no way the misses was going to hook up a PTO generator if needed. I didn't want to be messing with a PTO generator out in a storm either. Three of my neighbors have the noisy screaming 3600 rpm generators and I refused to add to the noise. A 1800 rpm diesel generator was out of my price range, and not very portable. I wanted 240vac to run the well pump. I ended up with a Honda FI inverter portable generator. Costs more than I wanted to spend, but misses can wheel it out, plug it in, push the start button and be good to go. When running it sits outside, 12 ft from the bedroom window, and we can't hear it. We run it for a few hrs to chill down refrigerator and freezer and fill water tank then shut it down for a while. No need to leave it running all the time. My nearest neighbor is about 300 ft away and we can hear their generator over ours. We keep the generators 5 gallon tank full and keep 15 gallons of gas around and so far have not needed more than that for any outage.
/ Portable Diesel Generator Recommendations? #62
I got rid of my 15KW Onan PTO set years ago. Fine running machine, but don't miss that system one bit. I can't say if I would prefer that over a portable. Diesel portable probably no, gas portable, yes.
/ Portable Diesel Generator Recommendations? #63
I'm considering adding a diesel generator to my backup options. I keep a supply of diesel on hand.
My concern is if there are any issues with these and how well they might work in cold temperatures?
I currently have a propane, portable generator that I run off of BBQ tanks. It is okay but I wish it had an electric start and I cannot tell the fuel level.
My primary goal for my next generator would be for use in the winter, so I can supply heat in the home. I would like to get something with electric start, just in case the wife needs to start it.
(Not looking for a standby unit like Generac - can't justify the $8k+ price tag for the entire project)
If you're patient you can find low hour diesel generators for a reasonable price.
I found this 20kw - 1050hrs for $4500 but I needed to build an "enclosure " that ended up being a small building 9x10. The place had a bunch of lp or ng take outs with a steel enclosures for sale but like you, I wanted diesel and always have plenty of that on hand. 20201008_155306.jpg
This little kubota "low boy" was my first shot at a diesel standby power set up and by all estimates should have been enough power @ 6500w for our needs. I may have been imagining it, but I heard both the generator and appliances complain during start up and when considering the cost of stuff like 500' deep well pumps, freezers and refrigerators. Not to mention the Mrs. wanted a more permanent installation that only required throwing a few switches. 20201118_151933.jpg
Iirc I paid (used) about $3500 for it and I built the little dog house it lives in.
/ Portable Diesel Generator Recommendations? #64
I've heard but don't know if true that Fuel Injection Gasoline generators don't experience anywhere near the fuel problems of carb units.
At just under 5k with freight and tax... it is a substantial investment... several co-workers have them for the very reason the anyone at home can start...
/ Portable Diesel Generator Recommendations? #65
The any one at home can start feature is important. The last power outage we had was on a weekday. I had to go into the office to work. Since our generator is electric start I could get it all hooked up. Wife could turn on and off as needed.
/ Portable Diesel Generator Recommendations? #66
Sure it matters, I stated that I have never seen a "newer" diesel wet stack, and I haven't...
I have quite a few newer diesels here, NONE of them have ever wet stacked on me, even when run for hours on end at low RPM's, with a light load.
Last diesel I owned that wet stacked, was an -------> old D-7 CAT.
I keep reading on this sight, guys telling newbs, about how you have to keep your tractor/diesel under load or it will wet stack, like when running a lightly loaded PTO generator. I don't believe it, and it's another thing, one newb reads and takes as gospel and repeats it.
IF, it's true, why doesn't it happen to any of mine??? I have 2, 3, 4 and 6 cylinder diesels, you would think at least one of them would have that problem under a light load, wouldn't you?
SR
I thought we were having a MEP generator discussion.
Didn't realize we were talking about YOUR personal experience.
I Have never had any of my diesels wet stack either. BUT on my MEP generator I follow the guidelines and give it a good load from time to time.
Probably a result of military using a 10KW unit for weeks on end when all they needed was a 3KW generator.
/ Portable Diesel Generator Recommendations? #67
FWIW, I regularly see used PTO sets selling very cheaply. There are things that unexplainably don't have high resale value and possibly PTO sets is one of them.
/ Portable Diesel Generator Recommendations? #68
The earlier comment about not wanting to mess with them in a storm is probably why. I sure would not, that is the only time we have outages.
/ Portable Diesel Generator Recommendations? #69
Since it appears you have natural gas to the house there are units that can be converted to run on natural gas. Of course you take a wattage penalty as nat gas has less energy in it than gasoline or propane.
Yes propane has more energy per unit volume but natural gas is usually a continous supply thru a meter vs stored on small tanks.
/ Portable Diesel Generator Recommendations? #70
A lot of folks say they wouldn't want to mess with a pto genset, it's out in the barn ect... Do you keep your portable out in the barn???
Keep the pto generator handy, just like you do your bigger portable! OR, build a shed for your pto generator, just like you do for your stationary generator!
SR
/ Portable Diesel Generator Recommendations? #71
Many people aren't well organizd. I have known many wealthy people who couldn't lay their hands on a working flashlight when it was needed.
/ Portable Diesel Generator Recommendations? #72
Amen to that... and 80 year old widows totally organized and prepared...
/ Portable Diesel Generator Recommendations? #73
How long Natural Gas gonna keep coming down pipeline wid de electric off? Most de gas engines pumped it for years now replaced wid electric pumps.
Propane, don't forget "annual acceptable loss" due to system leaks. Industry has a standard shrink factor.
Ain't NO free lunch.
/ Portable Diesel Generator Recommendations? #74
I'm guessing Natural gas delivery is dependant on a working Inernet. Foolish how everyone puts all their eggs in this one big basket.
/ Portable Diesel Generator Recommendations? #75
Have lost electricity many time, sometimes for an extended period (days) due to hurricanes. Never once have I lost natural gas.
/ Portable Diesel Generator Recommendations? #77
My Dad picked up Kubota 6500 portable [it's on wheels] genny. Diesel, water cooled.
It is run through a whole house transfer switch and independent breaker panel with all the important circuits [water pump, furnace, kitchen etc.]
It lives in his garage and is quiet for a diesel and very fuel efficient.
The best part is he got it used for $1200. They list new for north of $6k!
/ Portable Diesel Generator Recommendations? #78
I know where everything is, it is more that I am space challenged. Example, the backhoe attachment is behind the wood splitter which is behind the brush mower which is behind the lawnmower which is behind my pickup. So getting to the backhoe means moving 4 things.
/ Portable Diesel Generator Recommendations? #79
When I mntioned Internet, I wasn't talking about at the end user, but more of control of pumping stations and the system as a whole. It would be interesting how they manage their system if not by Internet.
(12) Round Grass Hay Bales (A66408)
(12) Round Grass...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2013 KENWORTH T800 WINCH TRUCK (INOPERABLE) (A65643)
2013 KENWORTH T800...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
