"Portable" Arena
   / "Portable" Arena
Re: \"Portable\" Arena
SPF = Spruce-Pine-Fir
Plain old untreated white boards.
Dave
   / "Portable" Arena #12
That is a great idea. Much cheaper and better looking alternative to the steel panels IMO.
   / "Portable" Arena #13
</font><font color="blue" class="small">( That is a great idea. Much cheaper and better looking alternative to the steel panels IMO. )</font>
Yeah, I agree with Zuiko. I'd still be worried about longevity but looks wise it is definitely nicer than the steel panels. In fact I had to look at the first picture a couple times to determine that it wasn't a built-in-place permanent structure and really, still can't tell.
Nice job.
Mike
   / "Portable" Arena #14
Just goes to show that if you hang around these boards long enough someone will come up with the solution to your problem. Dave, it's beautiful, and exactly what I need to do to replace my 120 x 240 foot ring. I think I'll make it smaller (we're not doing barrels anymore), I like the size of yours. Great job!
   / "Portable" Arena
Thanks Kevin, Poppa and Zuiko. /forums/images/graemlins/grin.gif
What a coincidence Kevin, that size arena is almost exactly what we plan to build in the future, only 120' x 200' (the wife is obsessed with the 5:3 ratio, so it will be a little shorter than yours).
Dave
   / "Portable" Arena #16
What size rebar (diameter) did you use? How long did you cut them?
   / "Portable" Arena
The re-bar is 48" long before bending. The bend length is probably about 10"-12" overall (including the arc). I was lucky enough to find that Lowes carries bundles of 3/8" x 48" pre-cut rebar, so all I had to do was bend them.
Dave
   / "Portable" Arena #18
<font color="blue"> so all I had to do was bend them. </font>
What did you bend them with?
   / "Portable" Arena #20
You could easily paint the rebar too.
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
NEW Fork Extensions (A59000)
NEW Fork...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
3410 (A47477)
3410 (A47477)
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
