Poor man's side by side
/ Poor man's side by side #142
:thumbsup: :applause:
Took today off to get a big chunk done. Here's four hours worth of work.
Passenger's side done
Started tracing fancy curved brackets for body mounts... then just did this
They actually had to be hammered in (pass side needed an 1/8" shim), so we'll see if they stay in place once the body starts moving on the trail
Metal work on the back is done! Turned around to get to the front
I HATE RUST!!!
Hit it with the flapper wheel to see what I was dealing with then cut out the worst spots
Then probably an hour later I had them all filled
/ Poor man's side by side #145
Lotta work if your gonna get rid of it :)
/ Poor man's side by side #146
Looking good! That's going to be a nice side-by-side! :)
Thanks guys.
Meh, it's good practice for me, and a nice rig for whoever buys it... and with any luck I'll play with it a little to make sure it's all good before spring. The bridge is going in on the trail as soon as the frost is out of the ground... the goal will be to see if the Tracker can make it around by itself. Should be fun! :)
/ Poor man's side by side #148
Nice work!
/ Poor man's side by side #150
I venture to guess that 2x2 will last longer then the rest of the vehicle but I get where you're coming from.
/ Poor man's side by side #151
Nice work on a neat project! I think you should go ahead a fab up a 3pt hitch on the rear so you can pull a blade or a disc!!!!! Now that would be the cat's meow LOL. Keep the pic's coming.
Thank you kebo!
If the Jeep sells I may very well be towing my grader (to be finished after the Tracker) with the Tracker... although it doesn't require a 3pt hitch... but you never know! The wheels never stop turning in this twisted mind of mine. LOL
Thank you kebo!
Finally got this one off my phone... I was stuck trying to turn around in the trail
Body work continues... first crack at bondo
Far from perfect, but good enough! Bring on the paint
/ Poor man's side by side #156
Any updates on this great project NS?
Well thank you for asking! I've finished painting it, though I think I'll do some of the interior paint... basicly the A and B pillars because they're so visible with it being so open. Also if you look at the last pic on here I'm mocking up a TJ roll cage that I've got to cut and splice in a couple spots...
... but I've picked up my next project this weekend, so I'm itching to get the Tracker done so I can start on it! :)
Unfortunately I didn't get in the garage at all this weekend, but I'll be putting a push on to have it done asap. I'll post some nice outside shots once she's done.
/ Poor man's side by side #158
I never even saw that roll cage the first time I looked. But it looks good now that I looked again. Do you have anymore photos of the roll cage?
What is this new project? Will you create a thread about it?
Don't worry, I'll take lots of pics. I was just mocking it up to see how bad I'd have to hack it to fit.
Yes I will start a new thread for the new project... but you'll have to wait and see!
Oh wait... I do have a pic...
Well, pulled her out to clean up the garage & make room for the next projects
I'm re-considering the roll cage... it may of may not get done... so as far as this thread's concerned, she's done! Hope you enjoyed it, and thanks for posting/ reading! :)
535 GAL WATER TANK (A68842)
535 GAL WATER TANK...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2013 FORD F-150 PICKUP TRUCK (A66091)
2013 FORD F-150...
More info coming soon. (A64557)
More info coming...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
