poor compression on my JD L112
/ poor compression on my JD L112 #1
rayce
Dunmore Alberta
JD l112
I have a JD lawn tractor that has only about 20 -30 psi compression, pulled the head and I cant see too much wrong with it asice from average wear. my question is can the steel valve seats on this engine be the cause? can they get loose? it is a Kawasaki 460V engine.
Thanks Rayce
/ poor compression on my JD L112 #2
You can check your valve clearence. They need to open and close properly to give you the right compression. If you put it on compression stroke you can check with a feeler gauge. Set them within specks then check compression.
John Deere 4520 (A60462)
John Deere 4520...
2022 EZ-GO ELITE...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
Champion Vibratory Roller (A60462)
Champion Vibratory...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
