Poor cab heat
/ Poor cab heat
tglass
Since your engine is different than a 3520 or 3720, does the heater hose return line "T" into the radiator hose on your tractor?
/ Poor cab heat #102
Well, I'm going to thrown another idea at this. I been looking at the water pump and thermostat area on JD parts again. I noticed something unusual for the thermostat area and its gaskets. It shows a gasket( #4 on graphic) and it looks to be typical gasket paper. Then it also shows another gasket below the thermostat(#6 on graphic) My guess is that it is rubber and probably has a slit on its inside diameter and it actually fits over the the perimeter of the thermostat. What is unusual is that I normally wouldn't see this combination together. Typically, It is thermostat/ paper gasket OR thermostat/rubber o-ring-like perimeter "gasket" that acts as the seal for the top radiator mounting flange. I haven't seen both used together before. Now, what if they MUST be used together to create a tight seal so no coolant excapes to the radiator thru the upper radiator hose. Is it possible that the #6 rubber gasket is missing from the perimeter of the thermostat, thus coolant could flow around the thermostat(even thou it is completely shut internally) and allow coolant into that big oversized radiator just enough to not allow engine to warm up. If any mechanic was not used to seeing this type of design before, it could easily be overlooked during the thermostat removal, testing ,and reinstallation process. {the thermostat would be sloppy in its bore thou} You had mention once that you measured 77F at the radiator top tank on a 50F day with 125F at the engine block. Did the 77F get there from just the transfer of heat with stagnet water, or was it thru some warm water "flow" that allowed that temperature to rise to 77F? It wouldn't hurt to ask the mechanic if he remembers the #6 gasket(rubber, I assume) under or around the thermostat he tested for you?
/ Poor cab heat
Catman
Since you have been looking at the Jd parts on line, I have a question for you. In the water pump diagram, #32 is listed as a plug. Plug for what? Could this be removed and used as a return for the heater hose into the water pump? Then it would be plumbed like the 4x20 series. I don't know if this is a suction port or its purpose. I'll ask service manager tomorrow.
/ Poor cab heat
Nice idea but I see a problem with that explanation. The engine promptly heated up when the return heater was completely pinched off and cooled again when hose was unclamped at idle. If the thermostat was allowing coolant the flow past it, then I would not expect the engine to heat up at all, irregardless of the return heater hose clamped or not. I will still ask them about your possibility. Keep considering the various possibilites.
/ Poor cab heat #105
Hi radman, I looked at #32 plug and see it uses a copper washer on it (#31). A copper washer suggests to me that it is a plug used for flushing out the system. The graphic isn't detailed enough for me to tell you exactly where it goes positively. I would need to be able to rotate that graphic. My best guess is that it is water/coolant coming out of the cylinder head, thus used for flushing the engine and the idea of the copper washer is that they are reuseable(sometimes). If correct, then it is on the "pressure side" of the system. I wish I could see the casting of the water pump itself because it should have a by-pass passage between T-stat housing and water pump impeller. If plug #32 is in the by-pass passage, then there would be maybe some suction, but yet some pressure from the cylinder head flow. I can tell you this is a fine line at this area with the water pump so close. I do have this experience to share with you, back in 1988-1989 CAT had an engine that the OEM manufacturer (Freightliner) plumbed their heater return directly above the by-pass tube(about 6-7" away from the water pump) and the complaint was poor heat in the cab. The solution(Update) was to reroute that heater return to that special suction fitting on the water pump itself. To me; that special fitting on the JD water pump would be that lower #24 plug. See how it goes directly into the water pump suction. [one can tell because we know that bottom radiator hose fitting/smooth barbed has to be suction. I think your oil cooler coolant return goes to that "special" fitting (lower#24) Again, I assume that because of the oil cooler graphic and its hoses[ it gets pressure for the rear of the block, goes thru the oil cooler, then forward up to the water pump at lower #24 plug(suction)] I am curious about pipe #28 and pipe #30. JasonMac says his 3720 heater works fine in New Hampshire, So I keep wondering where is your heat escaping to and/or why the engine doesn't generate enough heat in the cooling system. Even the oil cooler actually takes heat away from the water until it gets up to temperature and then when a engine gets worked really hard, then the oil is generally 20-40F hotter than the engine coolant temps(CAT systems,anyway)
/ Poor cab heat
Lower plug 24 connects to a line which goes to the base at the attachment of the spin on oil filter. I assume that is an oil line. (It is listed as 12 under oil filter category). Upper 24 plug seems to be the feed hose connection for the heater, although the diagram lists it as a pipe.
Maybe the return heater hose could be connected by a "Y" fitting closer to the suction side of the water pump instead of a "T" fitting near the bottom of the radiator.
/ Poor cab heat #107
radman1 said:
tglass
On mine (3320) the lower line is "T'D" into the radiator hose. Looks kind of like a cheap field installation, but I know it's not. Saw mine come off the trk. when del. to the dealer. The top hose comes off the water pump next to the top radiator hose. Heats great, but after looking at I don't know why.
/ Poor cab heat #108
After reading CATMAN'S post again and looking at my tractor, (although not the same model) it makes sence. Must have a bypass passage built in the water pump or the heater would never get hot. Hmmm
/ Poor cab heat
turbo36
Did you have the heat problem on your tractor checked?
/ Poor cab heat #110
radman1 said:
turbo36
Not yet, I sent the dealer the link to this thread hoping I didn't have to go through all the same worthless efforts you have endured but he came back with the same suggestions about the air conditioner switch on, air in the lines, blah,blah,blah, so apparently JD still doesn't have a grasp of the problem. I'm not very happy with JD right now.
/ Poor cab heat
Yea, JD corp doesn't have a handle on this problem. It seems like they are waiting for a field guy to come up with a fix. Service manager is coming out to my house on monday (2 days) to try other solutions. We are going to try rerouting the return line to the left side of the water pump. There is a plug there. (#25 on JD part list) Remove that plug and add a threaded insert with attachment for return hose.
There is also another plug near the suction side of the water pump (#24 on part list) which has an oil cooling water line going into it. May also try putting a "T" threaded fitting in that port - one for the existing oil cooling line and the other for the heater return hose.
Another thought would be plumbing the return hose into the plug on the left side of the block where the engine block heater goes.
We also are considering putting a restrictor in the return hose line to slow down the flow.
We are also going to install a new thermostat and make sure all the gaskets are in place around the thermostat as suggested by catman. The thermostat had been previously checked in hot water and seemed OK.
I did clamp my heater return hose yesterday with a vise grip and then started the tractor cold at 29F and windy. At fast idle the temp gauge was 1/2 way over (in the green range) in 11 minutes. Removed the clamp and temp began falling a 1-2 minutes to 1/4 way over. Took tractor out and did hard blading work for 10 minutes and heat went back up to 1/2 way and heat in the cab. Worked tractor for 10-15 more minutes then let it idle. It took about 15 minutes to eventually cool the engine/water back down and blow cool air again in cab.
My dealer just got in a new 3520 cab and checked it for heating this am at <30 outside temp and it performed normally. Heated up to the 1/2 way point in 10-15 minutes and 98F at the vents in the cab at no load. This tractor is plumbed exactly like the 3720 and had an engine block heater installed just like mine. The 3720 has an intercooler but this is in no way connected to the water cooling system.
I'm also considering putting some foam insulation wrap around the feed and return hoses to keep the heat in.
/ Poor cab heat #112
radman1, While the JD service dept. have the thermostat out; have them look inside its bore and see if there might be a casting flaw/crack in that area. If you will notice how close #24 upper plug(current heater supply connection) is to that bore of the thermostat, then it is worth a good look anyways. You might mention to them about testing the intake air heater and make sure it is working properly. (Engine needs to be cold to test properly). The idea of an intake air heater on a diesel engine is to warm the incoming combustion air during cold start up to help eliminate white smoke complaints and improve combustion heat inside the cylinders until coolant temperatures increase to a programmed/preset level. Although, this wouldn't explain your cooldown after you worked your tractor hard and had it up to operating temp. Your service manager brings up about the air conditioner system being on; What if the A/C controls aren't working properly and the A/C is constantly ON? Is there an easy way to remove the A/C compressor(pump) v-belt and this would isolate that system from possibly removing any heat from the cab heater under the roof. I won't instantly jump on rerouting heater hoses as a first step, because other 3720 are operating properly with that same circuit of coolant flow. The A/C problem does make a lot of sense, because it removes heat from the cooling system circuit and the engine can't generate enough heat to compensate for that loss at light loads. Good luck on Monday and keep us informed. PS. This would also explain way you can clamp that heater hose circuit and the engine temp rises(this also isolated the A/C and cab heater area from any coolant flow and an improperly working A/C system couldn't effect the entire cooling system in a negative way)
/ Poor cab heat
We have watched the a/c compressor and it is not engaged/running during our tests. That was one of the early considerations.
We will check out your other suggestions as well. Thanks for the help.
/ Poor cab heat #114
Radman1, Did JD come out and try anything worth sharing with us on Monday?
/ Poor cab heat
Update. Service mangager has decided to wait at this time before trying any modifications. JD corp recommended he not try anything at this time and let them figure out a solution. My dealer tried to order a new 3720 cab from JD corp and they are putting tractors on hold for no sales til Jan. I don't know if this is just for that model with cab or if other tractors are involved. Dealer thinks it is due to the cab heating problem but JD corp won't say.
/ Poor cab heat #116
Radman: your idea for insulating your heater hoses is just what semi-truck manufacturers do when they install their "Arctic " package for cold weather applications. They wrap heater hoses and fuel lines. I don't know how much you will gain, but it should be pretty cheap and simple, so I would go for it. I do have a question for you: Are you able to leave the cardboard in front of the radiator(JD installed) when you worked your tractor the other day or did you remove it? Just curious. I assume you left it in.
/ Poor cab heat
The cardboard has been removed from tractor past 2 weeks. All the recent posts, temp reading and when working the tractor have been without the cardboard in place. Engine will heat up to operating temp in 10-11 minutes if I clamp the heater return hose.
/ Poor cab heat #118
Update: My dealer is going to change from the 160 degree thermostat that comes with the tractor to a 180 degree used in other JD equipment, Also, they said something about checking the mechanical cable that goes to the heater control.
/ Poor cab heat #119
turbo36; Did your dealer say if this was their idea for these changes OR did that info come from the factory engineering group? Just curious if you happen to know?
/ Poor cab heat #120
This is a dealer idea. I sent my dealer the link to this thread but they pretty much blew it off so I will let them try what they want while I contact Deere directly to see if I can get a response.
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
213073 (A64276)
213073 (A64276)
2015 Teupen TL54J Crawler Articulating Boom Lift (A61572)
2015 Teupen TL54J...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
John Deere 302A 50HP Loader Utility Tractor (A61572)
John Deere 302A...
