Poor cab heat
/ Poor cab heat
wolc123 said:
What will you do next summer, put the 160 thermostat back in? Would not the higher block temperature, especially with the additional air-conditioning load, shorten engine life?
I don't think overheating will be an issue. I ran the tractor this summer on 100F days while bush hogging. The temp gauge would climb to just over 1/2 way to the red zone. Overheating doesn't seem to be an issue with this tractor. Using the tractor today with moderate load, the temp gauge climbed to about the same level as when I used it this summer during the heat. At 180 the thermostat should open fully. A tractor that overheats with a 180 thermostat will likely overheat with a 160 thermostat. It is probably more detrimental to a diesel engine running at too cool of a temp than running at 180-200. A 160 thermostat seems almost too low. I believe most auto thermostats run in the 180-200 range.
/ Poor cab heat #132
After reading in your post that with the heater return line clamped the engine warmed up it reminded me of an emergency fix for autos. If you have trouble with your car overheating on a very hot day you can turn the heater on high and that will allow the heater core to act like a small radiator and sometimes it will give you enough extra cooling to get where you can get it fixed. Sounds to me like you are having kind of a reverse problem when heater is on gives too much of a radiator and cools the engine down. If you have the heater set to off or the coolest heat temp etc what does that do to engine temp. If engine temp is more normal with it off. I would ask the dealer to try a cheap easy temp fix to see if it helped. get some fittings and adapt the heater return line down to where it runs through some 1/8 inch metal tubeing (as in plumb in a 1/8 inch bell fitting and then go back to regular heater hose size.) hopefully this will slow down the flow through the heater core. If that works then with the dealers blessing you could keep it in place and be an easy fix while JD is coming up with a permanent fix. If by some chance it works and JD uses that for a fix I want to know about it so I can ask for royalties.
/ Poor cab heat #133
Restricting the flow through the Heater will not acomplish what he wants to do which is get more heat in the cab. He is not trying to maintain heat in the engine!!!!! If he wanted to do that he could just leave the heater shut off. The real issue is the motor is not produceing enough heat to provide some extra heat for the cab.
/ Poor cab heat #134
DWMaster maybe you should read my entire post before you post your comments. I believe I explained in my post that the problem might be the heater core was acting as an addtional radiator which was providing an extra amount of cooling. When I read his earlier post I noticed that when he clamped off the return heater hose he mentioned that engine temperature went up. For what ever reason it might be. The physical indications are that restricting the water movement through the heater core caused the temperature of the motor to increase. My idea was expanding on that observation. Do you perhaps have a better idea for him to try ?
/ Poor cab heat #135
radman1 said:
I did clamp my heater return hose yesterday with a vise grip and then started the tractor cold at 29F and windy. At fast idle the temp gauge was 1/2 way over (in the green range) in 11 minutes. Removed the clamp and temp began falling a 1-2 minutes to 1/4 way over. Took tractor out and did hard blading work for 10 minutes and heat went back up to 1/2 way and heat in the cab. Worked tractor for 10-15 more minutes then let it idle. It took about 15 minutes to eventually cool the engine/water back down and blow cool air again in cab.
DWMASTER
This is the part of his thread i was responding to
/ Poor cab heat
If I turn the heater control valve down completely the tractor will warm up more but still not up to operating temp. My understanding is that there is always some flow through the heater core even when the valve is turned down. I have tried partially clamping the return hose. This will reduce the return flow and help heat the tractor. However, now less flow goes through the heater core and thus less heat is put into the cab. Net effect is warmer engine but not enough heat in cab. At one time we considered putting a valve in the heater hose and partially closing it but the net effect would be the same. I need a hot engine and hot cab.
/ Poor cab heat #137
That makes sense I did not think about recducing the flow would reduce heat in heater but actually that is what the temp control does duh.
I dont remember all of the posts but have you completely totally enclosed the front of your radiator. I know you said you did not want to have to do that on a 30,000 dollar tractor. My list price 48,000 dollar silverado actually has a cover to do just that for cold climates. It covers everything so no air comes in the front of the truck just what it gets underneath
/ Poor cab heat #138
No I Don't.
Interesting observation on my 4320 the other day. I was out when it was -5 below and -40 with the windchill. I shut the heater off for a while then turned it back on. The temp gauge climbed and then fell at least 1/4 to 3/8 of an inch. That heater system and core robs alot of heat! The good news is is even at those temps I had the fan and temp on low.
/ Poor cab heat #139
I've got to hand it to you for your patience. If it were my tractor, after all this time I'de be steaming when I walked in to the dealer, He and Deere would probably be so tired of me calling they'de probably offer to give me my money back. I'de still refuse. This is getting interesting. Got to hear the outcome.
/ Poor cab heat
The first time I talked with them, I was getting a little mad. But they have really been trying to help solve this problem. Also the weather has really been good to me so far this year. Cab with poor heat is still much better than sitting out in the wind and a lot quieter. On a cool, sunny day, the amount of solar heat through the windows does a good job of making it comfortable in the cab. Suppose to be in 30's this weekend and will see how it performs in colder weather and hotter thermostat.
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
