Poor bucket lifting power
   / Poor bucket lifting power #1
SoreButt
Iseki TL2300F
My compact 4wd tractor loader has weak lifting power. I've owned other tractors, and they lifted much more. The bucket can tilt and lift double what the arms will lift. I've opened the knob that slows the flow to the loader. Any ideas? I have several items needing moving that it won't lift.
   / Poor bucket lifting power #2
Which John Deere model is this and which "knob" did you open?
   / Poor bucket lifting power #3
Yeah, model number would help us but the JD compacts are not known for having good loader lift capacity. Almost all other compacts will have hundreds more pounds of lift.
   / Poor bucket lifting power #4
Have not noticed lack of lifting power with my JD 4300. Have significant ballast and rear wheel fluid, and still can lift enough with the loader to bring the rear wheels off the ground.
Had a couple occasions to operate similar size hp New Holland and Kubota loader tractors without near the lift power in the loader as my 4300. Don't remember the model numbers, and it isn't important. But left me quite pleased with my JD 4300. No good comes from bad mouthing other brands.
   / Poor bucket lifting power #5
Not bad mouthing, that's why I asked a model number. The 1 and 2 series sub compact and compact tractors are known for poor lift capacity compared to simular sized machines from other brands.
   / Poor bucket lifting power #6
I've got a 1025R and am easily able to lift the back wheels off the ground with the loader if I don't have enough weight on my 3 point.
   / Poor bucket lifting power #7
The tractor he lists is the Iseki TL2300, no mention of JD.
OP - get the hydraulics tested, you might be able to add a shim or so for more power.
   / Poor bucket lifting power #8
It’s in the John Deere sub section
Sorry, lost my link to this page and expected email updates.
It is a 770 with a model 70 loader.
   / Poor bucket lifting power #10
I looked at the specs of your tractor and the loader is rated at 700 pounds at the pins. Of course you don’t lift things at the pins so a load in the bucket is less. Forks will make it even less. I own a newer JD 2025r and put a pressure gauge on it, it was on the low end of spec so I turned it up. I’m not sure if you can do that with yours or not.
Year: 2013 Make: Chevrolet Model: Impala Vehicle Type: Passenger Car Mileage: 167,032 Plate: Body (A48082)
Year: 2013 Make...
Gorman Rupp 14C2 10 Series Self-Priming Centrifugal Towable Water Pump (A49346)
Gorman Rupp 14C2...
UNUSED MOWERKING SKID STEER PALLET FORKS (A50460)
UNUSED MOWERKING...
2014 CATERPILLAR 289D SKID STEER (A50458)
2014 CATERPILLAR...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
2021 CATERPILLAR 305E2 EXCAVATOR (A50458)
2021 CATERPILLAR...
