Pond Repair
/ Pond Repair #1
Redlands Okie
Oklahoma, North Central
Kubota L3560
More information coming later but i recently got a call on a leaking pond repair. I am told its spring fed with a hard rock bottom. I will go look at the site and gather more info. For now i am looking for suggestions on thinks to look for. I am familiar with Bentonite clay to some degree and pumps of various size from hand moveable to light truck trailor pulled. Same for various dirt moving equipment such as light dozers and excavators.
Any ideas or suggestions would be much appreciated.
/ Pond Repair #2
They've gone and Fraced a crack in his bedrock bottom and its going to take a lot of caulking to fill it.
heh...
The only earthquake I've ever been in was in Guthrie, OK.
/ Pond Repair #4
Interesting to learn where the leak is. I've always understood that rock is a very bad thing for holding water. Too many cracks and sealing clay to it never creates a bond that will stop water from flowing along the rock surface.
/ Pond Repair #5
Yes when I was a kid our neighbor had a pond with rock bottom. No matter how hard it rained, within a month it was empty! The guy eventually gave up trying to fix it and just built another at a different location.
/ Pond Repair #6
Good luck in fixing your pond. Based on my experience it might be hard and expensive.
When my pond was being built they dug themselves into thick (about 15 ft) layer of sand on the bottom. The builder put on few tons of bentonite and some plastic liner. The pond filled up few feet and dropped about a foot/day. I hired another bulldozer guy to spread another 14 tons of bentonite in the pond and cover it with about a foot of material. It dropped the leakage to about 1"/day. Then I bought a polymer sold by Seepage control company that claimed to built pond in sand. That dropped the leakage to about 0.5"/day at relatively high water level. The pond is still leaking at more or less constant rate and dropped about 8 ft in past six months. I called Seapage control and was told that there must be a hole somewhere otherwise the polymer would seal it. To make the story short we spent about 20000 on 0.7 acre pond and so far we have just a puddle. My suspicion is that the water follows the "hydrant" line or the hydrant line has a hole in it. Hopefully I will find time to figure out where it is leaking this spring/summer.
/ Pond Repair #8
How much is an acre of Line-x? That would definitely work.
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
Quick Attach Backing Plate (A65579)
Quick Attach...
Westfield Seed Auger (A66408)
Westfield Seed...
45K LB LOADING RAMP 25'X101" (A62613)
45K LB LOADING...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
