poly skid shoes
/ poly skid shoes #1
Dutch445
Elite Member
Upstate NY
JD X585
I have heard that somebody is making a plastic, poly,
or other material skid shoe for snowblowers. I'm thinking
more of the runner type, that are for walk behind blowers,
or front snowblowers for compacts and L&G tractors. This
type typically bolts to the side of the blower housing, instead
of being mounted on a bracket.
Does anybody know where they can be found?
thanks,
:D
/ poly skid shoes #2
Hi Dutch,
You could probably shoe your own without too much trouble. Try checking out the plastic suppliers in your area. I think that the white PTFE board would be your best bet. I know that material is out inside chutes and hoppers on bulk handling equipment and is very slippery. You would need to work out how to fix it to the shoes - maybe countersunk 3/8" screw or similar. Myself, I think the steel does a good job. Let us know how you made out.
Jim
/ poly skid shoes #3
Dutch -
If you have a snowmobile dealer in your area you may be able to get some free worn "slides" that have been taken off of snowmobiles (they wear).
It'd be a cheap way to try it I guess - I'm not sure of the longevity if you're dragging these on blacktop or cement though.
Good Luck!
Scott
PORTA POTTY (A68842)
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
WEATHER GUARD TOOLBOX (A68842)
WEATHER GUARD...
LANDPRIDE 48" BOX BLADE (A65057)
LANDPRIDE 48" BOX...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
