Poly 96" snow plows: which one?
   / Poly 96" snow plows: which one?
I have a Mahindra 4530 with a quick attach. I bought a quick attach plate from northern tool and welded a 8 1/2 foot steel western plow onto it. The plow was used with the a frame. I've found when plowing snow you want as much weight as posssible. Often you will be plowing with the plow slightly off the ground. The steel plow is heavier providing for better traction. I would stay away from poly or other light weight plows. I was having difficulty finding what I wanted so I made my own plow and it works great. My advice is don't put a light duty plow on a heavy duty tractor.
Does your loader have a float function?
   / Poly 96" snow plows: which one? #12
I purchased a 7ft front hydro.snow plow from Michigan Iron and equipment.Stout 7ga.steel,well made.You should check them out.
Too late: I've already purchased the Hiniker 8' 30" high Big Ox skid loader plow with the extra wear tabs and rubber snow deflector.
I dropped off the plow at my lake home. Without the benefit of a loader, I had to get creative.
Things got real when I knocked over my beer.
Mission accomplished.
The need to bolt the black bit now in a garage with the red bit out on the lawn will increase as winter comes.
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
