Pole saws... worth it?
/ Pole saws... worth it? #21
I have a hand pole saw and a Stihl Kombi with the pole saw attachment. The Stihl has less reach than the hand saw but is much faster. I only use the hand saw when I need the extra reach. The Stihl is more sensitive to dull chain than a regular chainsaw. I have 2 sets of chain and change them out as soon as the saw starts to lug when cutting. I agree with others that the saw will get heavy if you are constantly using your arms to support the whole weight of the saw. Also eye and ear protection is a must. Jim
/ Pole saws... worth it? #22
They are wonderful! Your neighbor doesn't know what he is doing.
I have used mine enough to wear it out (a Stihl Combi) trimming trails here and at state parks and forests (we do volunteer bridle trail maintenance).
I do get worn out after a few hours of lifting and swinging when I am doing miles of trails. When I replaced mine I elected to stay with the smallest Stihl because it weighs less.
I've never really had a problem with keeping the blade sharp. Since I don't use mine near ground level, it doesn't get the grit and dirt to dull the blade.
I have also bought the power scythe attachment, that's good for trimming light brush and under fences, and the blower attachment.
Ken
/ Pole saws... worth it? #23
All this pole saw talk got me wondering about the hydraulic ones the power company uses. They sure are quiet, but VERY expensive. Stanley Pole Saw Plus you need hydraulic source (tractor?) and hose. Think I'll scrape that idea.
/ Pole saws... worth it? #24
That's the sort of thing the hydraulic external connections on a Kubota RTV900 are for. Still couldn't understand why it wouldn't make more sense just to use a gas powered one and not have to deal with the hose issue :(
Now I would love to have a hydraulic saw that attached to the loader bucket so that I could drive down the trail and reach up and down with the bucket and do the trimming. But I want a bigger bar for trimming overhanging small stuff.
Ken
/ Pole saws... worth it? #25
Ken
That hydraulic pole saw is only 74" long. They are meant for use up in the bucket of a man lift. They are extremely powerful. They also have the benefit of not falling to the ground if you drop it. ;) And you never have to refuel it when up in the bucket. But you do have to put oil in the chain lubrication system.
Several of the Power Trac owners have considered them, since Power Tracs are all hydraulic. However, being tethered to a tractor with hydraulic hoses when pruning on the ground would get old, fast, as you would have to keep relocating the tractor. You could, however, attach it to the FEL fairly easily for high reach. You would just have to be careful about blade pinching and then bending the unit badly if you moved the FEL arms or steering wheel while it is pinched.
/ Pole saws... worth it? #26
I just ordered a Black and Decker cordless. Review forthcoming.
I just don't want the hassle of yet another two stroke engine, and I'm guessing in about four re-charges, I'll be done for awhile.
/ Pole saws... worth it? #27
I just bought the Black and Decker cordless and it worked great for me. I was surprised at how well it cut. It does not spin the blade very fast, but it cut the hard mesquite limbs like they were butter. It comes with a long extension pole that can be used for the really high limbs. The battery lasted longer than I could, so no problem there. If you are in much better shape than I am, you might want two batteries.
/ Pole saws... worth it? #28
I have the Husqvarna med/heavy duty string trimmer that accepts the saw attachment. Since it is multi-purpose it is not as long as the dedicated pole saws. This is one of the best tools I have purchased period. This saw not only sees duty for tree trimming but also I used it to slash back the invasive plants crowding our joint common driveway(~1200 ft). So to answer your question these work beautifully if you buy a good brand(Husqvarna or Stihl). The only question you should ask is whether you need a dedicated one or a combi. To test out a unit contact your local tool rental store as they should have one to rent.....Gary
/ Pole saws... worth it? #29
I have an el cheapo electric, I've had it for years and it still works beautifully! If you're a homeowner, well it beats the heck out of climbing up in a tree!
Two caveats....
1) They get heavy when you extend them out all the way (adjustable pole models like mine) and...
2) I wish the blade was perpendicular to the handle, instead of straight up, that way you could undercut the branch, then just sit the blade on top and let gravity and the chain do the work. Instead, you have to push against the branch as you cut it.....I may try to modify mine.
Oh, and invest in a good hard hat with the attached eye protection, you'll get tired of the chips falling in your eyes real quick!
/ Pole saws... worth it? #30
I too got a cheapo at the Depot, and it is great for what it is designed for. Light work (8" bar) overhead. Only limit is how many extension cords you own- and the amperage drop:laughing:
And now the sexist comment: Off the pole it is both light and quiet- perfect for the wife to re-size the pieces of stove wood I cut too long:confused2:
/ Pole saws... worth it? #31
I guess I don't trim as many trees as some, but when I recently bought a new, good quality manual pole saw, I was happy to find it did the job quite a bit better than the el-cheapo I had before. A good quality manual with one of the double cut blades, which look like my Silky saw blade, cuts darn fast and starts every time. It's a bit lighter than a chainsaw, too.
I'll second that. A good (japanese) manual pole saw is great for occasional work. Fast, light, no service, no gas, no noise....
I use the Silky Hayate 5 meter version.
HAYATE 420 16-Feet : Silky Saws
/Marcus
/ Pole saws... worth it? #32
My Stihl HT101 is pure awesome. I don't bother with regular chainsaws anymore. I use this thing for all cutting, limbs, logs & all.
I splurged - it was $600 (much like I splurged when buying my L3940). I would buy another one again tomorrow if this one disappeared. It is that good.
I've had no problems whatsoever with the blades dulling quickly - It stays sharp as long as any regular chainsaw's blade I've ever had, i.e. a good long time, cutting hardwood, saplings, whatever.
I mainly bought mine to raise the canopy at our home's wooded one-acre lot, & it did that to perfection. Since then I bought my 60AC property & have use it a lot there.
/ Pole saws... worth it? #33
Ken
I think Northern Tool sells something along those lines...
/ Pole saws... worth it? #34
I only own a remmington elc. poll saw. It has performed very well. I've gotten my $68.00 worth out of it if it quit tomorrow
/ Pole saws... worth it? #35
I have a relatively cheap John Deere pole saw. I find it particularly usefull for cutting ground level brush especially the clump type. I can reach the base & cut without bending & getting slapped around. Most extensive use has been clearing my property lines. Very thick fir & spruce 2"-3" in diameter & 10'-20' tall. I reach up & cut them off at about 6', then cut the top in half if necessary, then cut at the stump. Very easy to handle 6' pieces. Have cut sections out of blowdowns as thick as 10". Much easier to use for an extended period than a chainsaw for that type of work. MikeD74T
/ Pole saws... worth it? #36
I have a Stihl Combi, it has a pole saw, blade trimmer and a string trimmer. It is easy to change from one attachment to another and they all do a great job. I have had a manual pole saw, they are handy but any extended cutting will wear you out....maybe I'm just getting old. I think you will get a lot of use out of a good pole saw, I use mine for trimming bushes, limbs, grapevines , anything that needs cutting. I have been real pleased with the Stihl Combi. Good luck.
/ Pole saws... worth it? #37
I purchased a Black & Decker 18V pole saw and it works great, :thumbsup:. KC :D :D :D
/ Pole saws... worth it? #39
Arrived yesterday. Charged the battery overnight and used it this morning. It works great. As stated before, it doesn't have a high RPM, but it cuts quickly. Bruce, my battery lasted longer than I could too. Great tool.:thumbsup:
/ Pole saws... worth it? #40
After much research I bought an Echo PPT-265 Power Pruner for $590 OTD last month. Looked on all the classified adds and only found the Stihl models listed. I now know why. I refuse to buy Poulan anything.
This Power pruner will give your upper body a workout so don't complain later. After 30 minutes I was ready for a break. I could have rented a pole saw for $40, but I think operating it all day would have put me in the hospital. LOL. I have tons of experence operating a chainsaw as I owned a pulpwood truck when I was 22 y/o. I learned while operating this power pruner to remove large limbs in sections. Never cut over your head for obvious reasons and pay attention to the wind.
Echo is here to stay. With Echo you get "the most bang for the buck".Works perfect!
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
Pelican Paddle Boat (A65579)
Pelican Paddle...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
