Pole Chainsaws
/ Pole Chainsaws #21
I have the Stihl 131R Kombi with a pole saw attachment. Works great!
Mike
/ Pole Chainsaws #23
I recently bought the Dewalt 20v max pole saw and today was the first real use. Moderate fail :(
Had to trim some branches overhanging one of my fairly flat metal roof sheds.
About 2 inches in diameter, pine, about 12 feet above the shed.
So I get up there, plop, plop, quick and easy. But the branches were too heavy to drag off the shed roof.
So I try and cut them up further with the pole saw.
STALLED!!
Chain so tight I couldn't move it.
Get down on the ground.
Disassembled saw to find one sliver of wood about the size of a matchstick had popped the chain up and jammed :(
Despite the saw stalling I like it. Good balance, easy to use and I can use one of my light weight 2AH batteries or put on a beefy 12AH.
/ Pole Chainsaws #24
In case you weren't aware, start by cutting 1/4 worth of the branch from below. That way, when you finish by the top, it will break clean and not pull part of bark with it which could harm the tree.
/ Pole Chainsaws #25
I have an Echo pole saw. I use the same method you describe. I just make an undercut and them rest the saw on top of the limb. The weight of the running saw on the limb is sufficient to complete the cut and I don't have to hold the saw up.
/ Pole Chainsaws #26
I have a poulan gas saw and it cuts good but is heavy and is hard to start . Two yrs ago i bought a wen 40 volt extendable pole saw and it is awesome. On my farm i have cut lots of trees 6 and 8 inch limbs. Cuts like butter. and much lighter than the gas. I have the same blower and chainsaw, so i have extra batteries . The battery that came with the chainsaw is more powerful.
/ Pole Chainsaws #27
I have an Echo. I like it a lot.
MoKelly
/ Pole Chainsaws #28
Nothing like sitting in a comfy seat with a refreshing beverage while the saw does the work (y)
/ Pole Chainsaws #30
I have the 40V HF Lynx and do the same undercut on branches and let the saw do the work from the top. Lynx is a great tool for the price and I have it on the tractor cut to up 4-6" stuff on the ground to clear downed limbs into manageable lengths.
/ Pole Chainsaws #31
I recently bought a Makita 2xbattery pole saw with 'extension'. I went with the Makita because I've pretty much 'locked myself in' to their products due to the interchangeable batteries and their extensive range of "skins".
At full extension (the middle pole attached), it's a bit unwieldy until you get the saw onto the branch but once you let the 'saw do all the work' it works great. I find that it works best for me, and is more balanced (yes, it comes with an 'over the shoulder' strap & anchor point) when not needing the extra 'extension'. I use 2 18v 6ah batteries and have plenty of power.
I'm glad that I bought it as I've got a lot of Blackwood trees around the property and, for the larger diameter branches, my manual pole saw was exhausting.
/ Pole Chainsaws #32
I found that the heaver the power end is, the better or easier the tool works in the field. Case in point was when we got the Stihl Kombi the power end weighed more, while the saw attachment was lighter. My first thoughts was this is terrible!! But we got it into the field and it worked quite well and was easier to use while out, all day long.
Food for thought for you folks who use battery power pole saws.
/ Pole Chainsaws #33
I have the string trimmer attachment, adjustable hedge trimmer and edger attachments for my KM 131. It seems to be well balanced with each one of them depending on how I hold it when using each attachment.
I will probably get the chainsaw attachment at some point but I have a good Stihl pole saw with the extendable shaft so getting one for the KM 131 is not a high priority.
While on pole saws I will say I recently bought a Stihl PP 900 pole pruner and I’ve been very pleased with it. I got one extra middle section which gives me great reach from the ground. Obviously, this is for small limbs but it’s very handy with the reach it has. I haven’t used the lopper head that came with it, just the saw.
/ Pole Chainsaws #34
I posted previously on this thead advising that I bought a craftsman 20V pole saw (Lowes) and loved it. I need to update that a bit. I got a lot of use of it and more value already than what I paid for it but I am now finding that the connecting pins between the three pole sections are not quite conntecting - loose or worn - not sure (it got a lot of use). Anyway, the result is that at times the motor will not start up which is frustrating after you have stretched out to cut something. I don't know if this a common issue with pole saws with extensions or not. I will try to fix that somehow.
Now, even though I have this issue, I get so much use out of a pole saw, I decided to buy another one and I got the same kind because I think I can fix the other one and because this way I get the same battery - so now I have two pole saws, a weedeater and a blower, all using interchangeable batteries. But for the utility of that, I may have tried a different pole saw.
/ Pole Chainsaws #35
I have an EGO polesaw...does the job quite well when using a 5.0 A/h battery. Reasonably well balanced without the center extension. With the extension it goes out to12-13 feet, it's tough to maneuver, but like Wagtail's Makita, once on the branch, it's fine other than the occasion pinched chain.
Most of my yard tools (String trimmer, chainsaw, snow blower and the pole saw) are EGO brand and they all use the same batteries.
/ Pole Chainsaws #36
Yes, I've experienced the occasional 'pinched chain'. It happens on the larger diameter branches, especially due to the angle of the cut.
Fortunately the Makita that I have has a "reverse" function/button/switch that has helped get me out of trouble. (so far ;))
/ Pole Chainsaws #37
I have the large Stihl pole saw. I think it goes up 16' and I think I paid about $550 for it. It works great until your arms fall off from manipulating it. Great power for a pole saw.
/ Pole Chainsaws #38
I just got a Greenworks 8" 40V 2AH battery powered pole saw. Partly because I've got a Greenworks 40V weed trimmer a few years ago that still runs strong.
I've had it out twice now and so far it's working gtreat.
/ Pole Chainsaws #39
Heavy pole saw? I bought one of these.
It's not a panacea but it will save your back.
/ Pole Chainsaws #40
Echo saw here. Works great but it is heavy.
2021 Ford F-150 4x4 Pickup Truck (A61573)
2021 Ford F-150...
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
2019 PITTS LB35-33CS CUSTOM DELUXE LOWBOY TRL (A64276)
2019 PITTS...
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
