Pole building foundation question
/ Pole building foundation question #61
Back to compaction,
I've never seen a roller on tracks.
You realize a tractor also has big wheels to reduce ground compaction. Anything short of a vibratory roller is a compromise. A tracked skid steer will compact equally as good if not better than a tractor rolling back and forth. Neither are a vibratory roller but both work fairly well when used properly.
/ Pole building foundation question #62
I think material type and thickness of lifts would be critical.
Also something often forgotten in these discussions here on TBN, our members are from around the Globe. The method I swear by might not work at all for another member. Based simply on material type.
I built a pad for my house and shop. Used my Kubota pulling a 5.5 cuyd scraper packed with a sheep's foot pulled by my Ford. I had complete faith. Partially because of the available material, Missouri Clay with optimal moisture content. Partially because my lifts were thin. Partially because I made a Gazillion trips across that pad area.
/ Pole building foundation question #63
You’re right on on all accounts but I’ve yet to hear from a single person that actually owns a tracked skid steer say it’s useless for compaction. It’s easy to bash something you’ve never tried.
/ Pole building foundation question #64
Post #62
Just the normal compacting procedure. Has worked for many a year!
2016 Textron T/A 15 Ton Dovetail Equipment Trailer (A59230)
2016 Textron T/A...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61307)
2023 Kubota...
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
Giyi Gy-72 QA Mulcher (A60463)
Giyi Gy-72 QA...
2013 Ford Focus Sedan (A59231)
2013 Ford Focus...
2018 Forest River Flagstaff 228BHSE Pop Up Camper Trailer (A59231)
2018 Forest River...
