Pole Barn Site Prep and Back Fill
   / Pole Barn Site Prep and Back Fill
It will be either a 30x40 or 30x48.
You need to find another builder. It is his responsibility to have the dirt work done correctly. If you do it, and you do a poor job, how could he build a quality building?
This company builds lots of barns around here with a good reputation. They list pad specs in their quote (must be able to drill through pad material with auger, and pad should be within +/- 3'') They will do some dirt work, but they prefer not to. Crews are mainly Amish.
   / Pole Barn Site Prep and Back Fill #13
Make the pad level if you can. I had an interesting time attaching my new to me backhoe after putting it on sloped pavement. Every time I raised it up with the stabilizers it'd shift sideways a bit, which made aligning the tractor more difficult. If you put implements on dollies it'll be easier to move them around on a flat surface.
   / Pole Barn Site Prep and Back Fill #14
If it is optional, go bigger. The only time you will not like it is when you pay for it. Later on you'll be glad you went bigger.:thumbsup:
   / Pole Barn Site Prep and Back Fill #15
I done the site prep for my 30x50 myself. Make sure you get all the grass sod and dirt scraped away. You don't want to put concrete over a loose soil base. Its a whole lot easier if you can get your site leveled without a building in the way ! My box blade did all the leveling...just put rippers down and scrap off the grass sod and made a separate dirt pile for later use. Then where the low spots were I just used the boxblade to take down the high spots and pull it to the low spots. Or you can rent a skid loader for the day. Once the barn was layed out I put 2 inches of stone down before they started building. Keeps the area free of mud when it rains...plus easier to just back a stone truck up and tailgate it...no building in the way ! The builder I used required a level site within 2 inches of grade.
   / Pole Barn Site Prep and Back Fill #16
For a pole barn you only need to make the worksite level enough to work on. You can backfill inside the barn (inside skirt boards) afterwards for final leveling. Whether or not this makes sense depends on the barn, the site, available pole length, and other factors, so I'm just giving general advice. I have built a couple on sloped ground and the downhill side just gets an extra skirt board. Fill and level the inside with gravel.
BEFORE SKIRTS INSTALLED:
AFTER:
AFTER:
Thanks - this is basically what the builder would like for me to have prepared. Another option for me would be to rototill the sod first, and then scoop it out with the loader. That might be a little easier. After I removed the base sod I would level it out with either the box blade or soil pulverizer.
   / Pole Barn Site Prep and Back Fill #18
There aren’t many areas on my property that are anywhere near level. When I built my barn in 1988, I did my own site work to get the experience and save a little money.
I graded to a slight slope to the rear of the barn, and like s219, I used extra skirting on the low end to bring the floor up to level.
So far, it has worked out well, that is if you ignore the fact I should have made it twice as large, and delayed putting in the concrete floor for way too long.
   / Pole Barn Site Prep and Back Fill #19
Amen to that.
   / Pole Barn Site Prep and Back Fill #20
I was thinking the same thing. A tiller should be able to break up the sod so you can scrape it all level and smooth. I used my tiller to finish the yard around my parent's pool when it was installed. I just went in circles with people jumping in an picking out rocks and roots. After a while it was smooth and level.
John Deere 2640 2WD Tractor with 146 Front Loader (A55302)
John Deere 2640...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
UNUSED Hydraulic Thumb Attachment (A47477)
UNUSED Hydraulic...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A54865)
2015 Freightliner...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
