Pole Barn Lighting
/ Pole Barn Lighting #11
try this site.
www.national-lighting.com
Gary a lowbay style fixture is generally used from 15' to 25' above finished floor.
There is also not a problem with moutnting FL fixtures above 10' I have industrial type fixtures in my building (32'x48' mounted at 12') I average 65 footcandles at 3' AFF.
If the space is unheated standard electronic t-8 can be used with a low temp atart ballast. tube guards will help the lamp warm faster. There are many different fixuters, ballast ouputs, and lamps to choose from.
IMO I would stay away from t-8 HO or any others. These sytems are more expensive and use more energy.
If you go with HID a Metal Halide Pulse Start system would be of choice. This is more efficient than old MH systems and almost as efficient as HPS(orange light).
Of course some of these system cost a little more up front but will pay for themselves with the energy saved verses older technology. Most times this is about a 2-3 year payback.
One thing to keep in mind is that the old t-12 system and some old HO systems are being phased out by legislation. So even though they may be cheaper to purchase now may have problems buying parts in the future.
Feel free to ask any more questions. I do work with energy efficient lighting for a living.
/ Pole Barn Lighting #12
HR --
Regarding your swithching. HID's are ment to be turned on and left on. Of course this does not mean you should not switch them just do not expect to turn them off and on all day long. I assume what your thinking is to be able to run only the lighting that you need to do whatever tasks. I would also recomend that you install a few FL fixtures for those time that you just need to "run in and grab something". HID' do have a warm up period.
Looks like a nice barn.
/ Pole Barn Lighting #13
Likewise the HPS, don't like being turned on and off and on and off and on and off. If you would need the genberal lighting on long enough to make HPS practical, then I recommend them for energy efficiency and the golden light is good enough for mose general illumination purposes. I don't recommend them for "task lighting" but the fluorescents are fine there.
Patrick
/ Pole Barn Lighting #14
Thanks Gary,
Sounds simple.. I think I can handle the fixtures, and the wiring back to the switch. I'll let the electrician hook up the switches to the box..
Pete
/ Pole Barn Lighting #16
Any time.
There really is a lot of information to digest about lighting. If one wants to take the time.
/ Pole Barn Lighting #17
16 feet is definitely LO bay. I just replaced out some 400 watt HID metal halide HI bay fixtures with 50 watt sodium fixtures in a warehouse, and have twice the footcandles at a far lower consumption. From memory, the HPS 50 watt draws 0.68 amps, and the 400 watt MH drew 8.2 amps. HPS is definitely more efficient in terms of lumen per watt.
An added bonus of HPS over MH or Mercury, CCTV cameras can see in HPS illumination, where they can't see effectively in MH or Mercury illumination. HPS has an infrared component the others don't to the light.
/ Pole Barn Lighting #18
Franz and CJ7,
Around here you see a lot of gas stations using some type of HID light in the canopies over the pumps, any ideas as to what type they might be? Is HPS the yellowish lights that the utilities use for pole security lights. I have noticed some are yellow and some are more white/blue. Anyway I like the lights in the gas stations, nice white light. I guess for just lighting a storage building the HPS would be good, but for a workshop I would think you would want better color rendition? What is a ball park price for fixtures and how many would you suggest for a 50 x50 workshop (woodworking, metal working, welding, auto repair).
thanks in advance for the info.
/ Pole Barn Lighting #19
HPS is the yellowish orange light, the ones you are seeing in service station canopys are Color Corrected Metal Halide.
CCMH is being used more and more in lo bay applications, like gas stations and machine shops.
Prices are highly dependant on fixture configuration, especially reflector and lens. You can often find good deals on Ebay, just search "Metal Halide", and Sodium. Don't get too concerned with all the plant light systems offered for sale to growers of certain substances farmed hydroponicly.
Be aware, MH while it appears close to daylight does not offer the best wavelength for certain jobs, and is poor quality light for welding and painting.
MH is also more expensive to run than HPS. You might want to consider HPS for overall lighting, with flourescent fill in lighting over work benches. If your vehicle work will involve car painting, consider flourescent in that area with D suffix tubes, rather than CW suffix for best color matching and fading in paint jobs.
/ Pole Barn Lighting #20
What is your ceiling height? Is this an open space or is it divided by walls?
PORTA COOL 2000 PORTABLE EVAPORATIVE COOLER (A59823)
PORTA COOL 2000...
2018 Caterpillar 320 (A60462)
2018 Caterpillar...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
