Pole Barn Heating Options This Winter
   / Pole Barn Heating Options This Winter #1
chantman
Anna, OH
N/A
Hi Everyone,
This is my first post. My family and I live on 5 acres in the country and just built a 24x40x10 pole barn. We are really excited about it. I'm going to move my 4-wheeler, mower, and work bench in soon, once we get electric installed. We gave in to my son wanting a couple of barn cats to keep out mice. I built them a nice little box house that is insulated very well and plenty of bedding.
Anyway, on to my question. I have a family friend that can spray foam closed-cell insulation on to my walls for $1/sq ft. This is a really good deal from what I'm told, and I think we're going to do it right away. Unfortunately this is all the insulating we can afford before the winter. The ceiling is still open with rafters, the ridge vent, and the overhang vents.
Due to the kittens, and wanting to be out there during the winter working on various projects, I would like to have some sort of heating system. I cannot afford a forced air propane unit right now. Here is my thoughts. If I have the walls insulated, I could buy a torpedo kerosene heater, and keep it on a thermostat to keep it just above freezing in the barn (35-40 degrees). Then when we come out to work in the barn, we can turn it up to 50 or so. Would the ridge and overhang vents be enough ventilation for the torpedo heater? If we have an average mid-Ohio winter (teens or 20's during the day), how much kerosene do you think I'll go through in a week?
Thanks in advance for any advice you can give me. Hope to eventually buy my first tractor or skid-steer in a couple years.
-Mike
   / Pole Barn Heating Options This Winter #2
Personally, I would only heat it when I wanted to work in there. The cats don’t need heat. In fact, assuming they have access to the outside any time they want, you could be inviting pneumonia or other respiratory issues with them going in and out. Probably not, with that large of an area. But they certainly don’t need heat.
Thanks for the info. I think you're right. I won't be out there all the time, and if the cats don't need it, then we should be ok. I'll just heat it when I go out there. Think we should go ahead with the wall insulation now?
   / Pole Barn Heating Options This Winter #4
Without doing something for the ceiling, and having ventilation up there, you might as well try and heat the outdoors. I have a 125000 btu lp ready that I use in my uninsulated 20x30 shop sometimes, but all the heat goes straight up. You can't feel it unless your right in front of it. I do have a 16' ceiling though. Even just putting some plastic up on the bottom of the rafters could make a big difference for you. Personally I would put money into insulating the ceiling before the walls
   / Pole Barn Heating Options This Winter #5
I’d definitely do the walls for that price. And as Tbrooks26 mentioned, getting a ceiling in there, even if left uninsulated for now, would be a huge help.
   / Pole Barn Heating Options This Winter #6
If you insulate the barn insulate the walls and ceiling. Salamanders are nice (I have a 125,000 BTU fuel oil unit with built in T-stat) but they require a fresh air supply and recommend a some kind of vent to exhaust carbon monoxide fumes. Mine burns less than a gallon per hour due to the T-stat that cycles it off at the desired temp. I also have a used mobile home 80,000 BTU furnace that runs on fuel oil.
Check with a local furnace repair person in your area for a used MH furnace. They usually have some used ones they've replaced for someone who upgraded to a more energy efficient model that run on fuel oil, propane, or natural gas that they'll sell cheap. I got mine for less than $200.
   / Pole Barn Heating Options This Winter #7
I agree with the others that some sort of ceiling will be of immense help, even plastic as mentioned.
Thanks George for the mobile home heater idea. We'll demo ours when house is built and I may move it's unit to the poor barn.
Edit: ceiling will block your venting need to do something about that.
Also install CO alarm
Sent from my SAMSUNG-SM-G890A using TractorByNet
   / Pole Barn Heating Options This Winter #8
Lots of good advice here. Keep in mind that if you insulate the walls, you need to finish them some way. As I understand it, all the spray foams need to be covered for fire rating. Also, if you don't finish the walls, the foam will quickly get damaged.
Are your trusses on 4 foot or 8 foot spacing? Just plastic, overlapped and taped, will make a tremendous difference but I don't think it will work well on 8 foot centers. If you do put the plastic up, it will serve as a vapor barrier when you finish the ceiling with something like liner panel. You can then blow in insulation. In total, budget $1000 to $1500 for the ceiling depending on how you do it to be complete, but the first step of the plastic is really cheap. If you do go with the plastic, think ahead about where you will put an attic access and chimney pipes so you can frame those in first.
Whatever you do, +1 on the CO monitor.
   / Pole Barn Heating Options This Winter #9
I like using the MH furnace because the heat come out the bottom at floor level so the garage heats from the bottom up. The furnace sits on a pedestal built out of 2x4's and I have ducts facing 3 directions. Furnace exhaust goes out through the back wall then up above the roof. I have 6" insulation in the ceiling and walls. Both ceiling and walls have 17/32" board covering. I keep my 18x32 pole barn at 45* when not in use (to keep the tractor and 2 watchdogs warm) and set it for 60 when I need to work in there. Only takes a short time to get it up to 60.
   / Pole Barn Heating Options This Winter #10
waste of time....in Ohio you will not be able to heat that building without complete insulation walls and ceiling and a big heater and a big fuel bill
I assume you have a dirt or gravel floor? Best you can hope for is heat from a heater while directly in front of it . I live right down the road in Greene county been there
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
2010 MAGNUM PRODUCTS LIGHT TOWER (A45046)
2010 MAGNUM...
2012 KENWORTH T800 (INOPERABLE) (A45333)
2012 KENWORTH T800...
Year: 2016 Make: Ford Model: Escape Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A44572)
Year: 2016 Make...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
1980 PULLMAN TRAIL MOBILE 3 POD PNEUMATIC TRAILER (A45046)
1980 PULLMAN TRAIL...
