Pole Barn For My Equipment
   / Pole Barn For My Equipment
How much wind can a structure like this stand?
I could not find a Wind # in the literature, I'm sure that Reeds would be able to answer that based on location and structure.
Maybe some will remember the carport that served as a temporary shed for the tractors, it has stood up to several wind events and is nothing compared to this structure.
   / Pole Barn For My Equipment #22
Don't make the mistake I made when they asked me if I wanted in floor heat I said no should of said yes.
You might look at where he is located. I doubt he has a need for any heat.
This is the Almost Deluxe Southern Constant Airflow Version!! :laughing:
It has a Ventilation Fan on the side! :dance1:
   / Pole Barn For My Equipment #24
That happened in a hurry! You didn't waste anytime. Noticed you said something about pea gravel. If you are talking about the floor, you don't want pea gravel since it won't compact. You want something with a variable mix of sizes like 3/8 to 3/4. Just mentioning it because I've messed with pea gravel before and never want to see any of it again. It's the rock version of quicksand when you drive over it.
   / Pole Barn For My Equipment #25
I Would Get Road gravel3/4" Or Smaller Or mixed
I put down 100 yds of 'road base'- mixture of sand, clay and large washed gravel, some up to 1" and rolled it in lifts. Crushed stone cost as much as ready mix here. Nearest pit is 100 miles.
Washed gravel is abundant .and reasonably priced, The 'pea' gravel I top dressed with is 1/2"+ and works great if a good base is under it.
It will disappear if put on bare dirt after a few good rains
2017 Ford F-150 Crew Cab Pickup Truck (A55852)
2017 Ford F-150...
KUBOTA M108S TRACTOR (A51406)
KUBOTA M108S...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2017 Ford E-450 LP Handicapped Bus (A55788)
2017 Ford E-450 LP...
1999 FORD F-450 SUPER DUTY SERVICE TRUCK (A54756)
1999 FORD F-450...
