Polarize the generator
/ Polarize the generator #1
Enrico8n47
1947 Ford 8n
What is the procedure to polarize the 6v generator? I replaced the generator, and was told it has to be polarized in order to work properly, somehow Via the voltage regulator. There are 4 wires going into the voltage regulator: 2 on top, one on the left (from seat position), and one below. The previous owner painted over the VR, so I have no idea what the 4 wires are for, and they're virtually impossible to trace unless I disassemble the hood/gas tank. Most of the VRs I've seen have 3 wires. Your thoughts and direction on this are appreciated.
/ Polarize the generator #3
I am also only familiar with a 3-wire voltage regulator on 8Ns. Perhaps the 4th wire grounds it? That said, you really need to know which terminal is which because you can immediately ruin the regulator if you touch a jumper wire to the wrong terminal. You usually take a short wire and just briefly touch the BAT connector with the ARM (may be labeled GEN) connector. This will create a spark and your charging system will be polarized. If you touch the FLD connector you will nuke your regulator.
John Deere 5525 (A60462)
John Deere 5525...
1992 21ft Four Winns 205 Sundowner Boat w/ Boat Trailer (A61574)
1992 21ft Four...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
