Poison Ivy
/ Poison Ivy #21
Old grandma cure (it will work). 1 bottle rubbing alcohol, 12 REAL asprin (Bayer,generic etc.), 1 block of chamfer (you can still buy it at most drug stores) pour about 1/3 of the alcohol out, crush the asprin and chamfer into a fine powder, mix it into the remaining alcohol, shake well, and dab mixture onto sores with a cotton ball. Jack
/ Poison Ivy #22
My wife makes a tea from jewelweed and keeps some in the fridge all year long. Works great to stop itch & heal sores from poison ivy. I wash my hands with chainsaw gas when working around ivy then wash again with soap & water or waterless handcleaner. Then use the jewelweed tea on the areas I missed. My SIL makes a strong jewelweed tea into a hand cream with beeswax & other ingredients. My BIL is a landscaper & keeps it in all his trucks. MikeD74T
Native American Remedies
/ Poison Ivy #23
N80 said:
However, almost anything will remove the oil from your skin. Any soap will remove it. So I'm not sure that I buy that the Zanfel removes it any better than soap. Also, I'm not sure where the conventional wisdom comes from that says the oil dissipates easily. I was taught, and it is my experience, that it will hang around a long time on skin, clothing and even a pet's hair. Now, removing the oil is the first line of treatment but again, warm soap and water will do that. So technically, after a warm soapy shower, there is nothing to remove and in that regard 'cleaning' would have no effect on a reaction that has already begun. At that point the only intervention that will work is something that interferes with the body's immune response such as corticosteroids and antihistimines.
An in-depth survey article is here: Poison Oak
As you note, the article agrees the oil is very durable, "Herbarium specimens 100 years old have been known to cause dermatitis." However, the article goes on to explain:
"...it readily penetrates the epidermal layer of the skin where it binds to proteins of deeper skin cell membranes. Before the protein bond can occur the catechol is oxidized to a more reactive quinone in which the two OH groups are replaced by double-bonded oxygens. In the conjugated state (bound to cell membranes) urushiol is virtually impossible to wash off. By itself the urushiol molecule (also called a hapten) probably would not initiate a full-blown immune response, but when attached to the cell membrane it becomes a 'warning flag' that attracts patrolling T-cells."
Here is what the Zanfel website says:
If you know within the first hour that you contacted poison ivy, sumac, or oak, some experts claim that plain soap and water might wash it off the skin. They suggest that washing is effective if you catch it within the first two to four hours after exposure. Other experts believe that unless you wash within the first 10 minutes, the oil will bind to the skin. Once the oil has bonded, Zanfel is the only substance known to remove the oil.
I would quibble with the last part as there seem to be a number of ways of removing the bound oil, with varying effectiveness: swimming in the ocean, lye soap, and the Tecnu scrub have all given me varying qualities of relief. What is clear is that there are two ways of getting relief, either by removing the irritant, or surpressing the body's reaction to it.
/ Poison Ivy #24
A bottle of rubbing alcohol with a spray head is what I use to keep Poison Ivy from spreading and I can scratch it...a feel good burn:), It takes a week for it to go away for me. I don't get it real bad unless I get it on anything other than my hands.
/ Poison Ivy #25
Zanfel does not work for either my wife or myself. Or it dosent work on the poison ivy on our farm. We have tried it on 3 seperate occasions, purchased from different retailers. Good "ol Calmine takes the itch out and 5-7 days later it is healed. Got the topical steroid creme from the doctor and it did not work. Calmine seems to be the best for us.
Now how do I get rid of the poison ivy that happens to be surrounding the 200 baby Norway Spruce that we have planted over the last 3 years? I am afraid to spray chemicals, so I have been weedwacking and will begin push mowing around them this year. That isnt a fun job.
/ Poison Ivy
Well I have tried several of the recomndations on here and I appreciate all of the feedback. However, I just can't take the itching any longer. I am going to the doctor.
/ Poison Ivy #27
I can't blame you for going, I woulda been there long ago for my shot....
Thanks for the suggestion for the Experiment Doc... I think I'll pass though ;)
Poison Ivy grows as single plants with three green leaves and the point where the leave join the stem is red. Poison Oak is a vine plant and I have seen vines at my house an inch thick and woody which is why I always use the brushbgone on it. I can get a pick of some poison OK at my house if ya'll want me to...
/ Poison Ivy #28
jshbryan said:
I was clearing a fence row Friday and got into some poison ivy. This stuff has me itching and scratching like crazy. I have tried the topical creams and nothing seems to help for very long.
I wonder if any of you know any home remedies I could try.
I have had poison oak every spring/summer; can't get around it out here if you are active outdoors. You'll at least get a little...
The best thing once you have the oil on you is either Technu or one of the other similar poison oak/ivy soaps, or good old fashioned home made lye soap. My Grandmother used to make lye soap; it was THE BEST! It would cut the oil and leave a little moisture.
Technu, Avon, and a couple other companies have pre-exposure creams. If you know you're going to be in it, this stuff will help.
When you know you might have been in it, CAREFULLY take you shoes and clothes off when you clean up; the oils will get on your clothes, and can transfer to your skin if you are not careful, compounding the problem.
Be careful while you are out, and be a cleanly as possible, especially if you gotta go potty; you DO NOT want poison oak/ivy there... :eek:
Also, be careful of the animals. If your dog or cat is out around the stuff, the oils will get on thier fur. When you go to pet them, the oil transfers to you. You CAN get it without actually touching the plant.
Keep that in mind too when you work on your tractor. I have got it while working around the tractor weeks after bush hogging in areas that had the vines.
Learn to identify it, in all seasons... Even in the winter, when it is just a stalky plant with no leaves, there is still oils on the plant. I have gotten it as bad in the winter as in summer because I was working around all those oily stalks...
Worst case, if Technu or similar product does not help, go get the shots...
/ Poison Ivy #29
No one has mentioned the temporary relief you get by taking a hot shower. Get the water as hot as you can safely stand it. It will itch like "H' 'E' 'double hockey stick' under the hot water but then the itch will be gone for a while. I use this method to get to sleep. Get out of the shower and put calamine on after the shower.
/ Poison Ivy #30
I'll second BrianW's recommendation.
Years ago we used to take those scalding showers and they felt VERY good.... then we learned that it's a mistake to do that. S'posed to make it worse, spread the oils, etc.
Since then we've read that, contrary to the wive's tale we'd been believing, it is GOOD to take the scalding hot shower. It brings the body's natural antihistamines to the rash. And MAN does it make it feel better for awhile!
We now have resumed our old practice of scalding showers when we do get it. I've sprayed RoundUp for 30 years and it's rare for us to come in contact with it unless we are more than 500' from the house. Mostly just me, mostly when I'm clearing brush, and mostly not actually in contact with it but instead being bitten by mosquitoes that have been in it. That makes for tiny little patches that ITCH like heck!
Phil
/ Poison Ivy #31
At the risk of sounding like Red Green, try spraying it with WD-40 until it runs and drips off...
My brother swears by it, and the one time I've tried it, it worked. It must lift the oil out or something, since WD-40 was developed to displace water -- which is heavier than oil.
/ Poison Ivy #32
If I am away from home and get into poison ivy, I use some tricks my grandfather taught me. Get some mud, make some if you need to, and rub it all over where you touched the plant. I've also had good luck washing off with crushed jewelweed (my Grandfather called it silverleaf). If I'm near the house, I wash off with plenty of soap and water. My wife's Grandfather thought that Old Spice aftershave worked better than soap (I've never tried it). As long as I know I touched the plant, and wash off soon enough with either soap, mud or jewelweed, I never get the rash anymore.
/ Poison Ivy #33
I found that a prescription steroid cream 'Triamcinolone Acetonide Cream USP, 0.1%' does a GREAT job of stopping the itch..
IF you start using the cream when you first start to itch it will keep the water blisters from forming.. If you start using it too late it also does a great job of keeping the itch at bay..
Its about $4 for 2 tubes...
Brian
/ Poison Ivy #34
Forget calamine lotion. Throw it away. They had that 60 years ago and that's about all they had back then. Ok for 1950, but we have better stuff now.
I haven't had poison oak for several years now, so I haven't tried Zanfel. Tecnu is OK, but best used soon after exposure. If it is really bad, you can get steroid shots that really do the job, but they lower your resistance, so the docs don't like to give them to you--at least that was the case when I had it bad a long time ago. There are some benedryl creams that might help. I get poison oak-like reactions from the rubber like stuff they wrap your arm with after you give blood--coban, I think it is called--and the benedryl cream does the job. Without the benedryl cream, it is just like poison oak and it lasts for 2 weeks or more.
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2019 PETERBILT 389 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 389...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
JOHN DEERE 7420 TRACTOR (A63291)
JOHN DEERE 7420...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59911)
2016 INTERNATIONAL...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
