po' boy back hoe
/ po' boy back hoe #1
kidr
I thought someone might be interested in this. I made a bucket to fit on a potato plow mounted to the FEL. It digs to about 2 ft as is. With an extention could dig to about 3 ft. without hitting the tractor on the curl. I use for planting and starting holes for the PHD in hard ground.
/ po' boy back hoe #2
Now that's slick! I bet you could make some nice 2ft deep trenches with that rig.
/ po' boy back hoe #3
How's the visibility? Can you see the scoop with it being soo close to your hood? I love it, and may make one myself!
/ po' boy back hoe #4
Im thinking about building something like that for my Case skid steer. I have a backhoe and excavator but some jobs like putting in a water meter, planting a shrub , or burying a landscaping rock. Sometimes the job only calls for a small scoop full of material to be dug and I hate shovels. Great job on the build. What kind of bucket is that.
/ po' boy back hoe #5
real cool, great idea. how does it do on long runs
/ po' boy back hoe
Visibility is not great,but it's better than hand digging.......I made the bucket from scraps.........I haven't used it for long trenches yet, but I think it will be fine for that. thank you for the complements.
/ po' boy back hoe #9
Neat.
I have been wanting a skid steer to 3 ph adapter for some time anyway and had been thinking that my sub soiler would be a good "prelude" to digging post holes.
Basically to rip down the line and open up a narrow furrow to tuck chain link fence into (critter control around garden plot) as well as to bust the initial crust for the PHD.
Trouble is swapping around between PHD and sub-soiler, but a backwards run with it on the front would solve that.
Probably a few other 3 PH "devices" I could use in combination with something else on the back too.
So, a nice solution - I will continue my search for problems to which it can be applied (-:
Thanks.
/ po' boy back hoe #10
Nice idea Kidr, I wonder how that might work for digging out roots from small trees and bushes? I have been thinking of ways to get rid of stumps with my little tractor without trying to rip them from the ground with a chain. If you ever use it that way let us know how it works out. Your project sparked a couple ideas, nice job and thanks again.
DTS
/ po' boy back hoe #11
DTS
I think a sub soiler would work very well at that if you used it sort of radially outwards from the trunk.
Then across the roots far enough out to be able to lift or split them.
Slow and tedious maybe, but not excavator scale cost of machinery.
/ po' boy back hoe #12
Thats cool. I am in the process of fitting a Harbor Freight Quick Hitch to a SS quick detach plate and my first impalement to install is the subsoiler. I want to install it so that the point is forward and I can work the subsoiler under roots and such and pop them out of the ground.
/ po' boy back hoe #13
Some roots can be 20 feet out so allow plenty of starting distance and work toward the mother stump a little at the time and quite a large root can be removed with a very small unit!
I am digging stumps out of my gardens with the ole Case 580 and some of these things take a lot of digging to get out! thanks; sonny580
/ po' boy back hoe #14
HEY MATE THIS LOOKS GOOD THIS WOULD BE USEFUL FOR ME FOR DIGING OUT SAGE BRUSH AS THE ROOTS AREN'T TO DEEP THX FOR THAT :)
/ po' boy back hoe #15
Hi all, I am a new member of forum. Would a newcomer be warmly welcome here? Good day you guys!!!
/ po' boy back hoe #16
New members very welcome
Introduce yourself in the new members forum.
Be sure and fill in lots of info in your profile so we can know where you are, kind of equipment you have, projects of interest, etc....all this helps answer questions you may have.
and, post photos of your projects..join right in:D
/ po' boy back hoe #17
That's very neat. I have been thinking of something like that. Good build project for the winter. Not a backhoe but good enough for many small jobs.
/ po' boy back hoe #19
I have been pricing out the bits for this, trouble is the skid steer adapter frame.
I already have a set of pallet forks and right now I'm thinking of trying a scheme that replaces the actual forks with a couple of lift arms, then something simple for the top link.
Yeah, I can get there from here (-:
/ po' boy back hoe
For A plate try atvpress on ebay . very heavy duty, fairly reasonable price. Mine came from there.It will almost double the usefullness of the tractor. Put on a box blade or rake and groom a steep bank. middle buster for roots.I use a carryall on the front to load hay in the barn . or to use as a workbench when working high up, fit with a railing for a scaffold (I know). The uses are as endless as your imagination. I think a very worthwhile investment.
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
Rolling Cart Base (A65640)
Rolling Cart Base...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
