PNEUMATIC backhoe thumb
/ PNEUMATIC backhoe thumb #21
I'm not sure that locking the thumb into it's clamped position would do a good job of holding the load. The load is probably going to do some shifting while being moved requiring a constant resilient force against the thumb.
I don't know if it has any application here but air over hydraulic is used in industry to control the speed of an air cylinder. An example is the power feed on a production drill press where the power is supplied by a pneumatic cylinder which is mechanically attached to a small hydraulic cylinder with a needle valve to control the feederate. Hydraulic power is not required, just air pressure.
/ PNEUMATIC backhoe thumb #22
The easiest, cheapest and best way to a have a mechanical non rigid thumb is to just use the hydraulics already on the tractor! :banghead: It's like trying to reinvent the wheel.
4022CFL (A59228)
4022CFL (A59228)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2021 ISUZU NPR (INOPERABLE) (A63569)
2021 ISUZU NPR...
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
Sellick S80 (A60462)
2023 Kubota L6060HST Compact Utility Tractor (A63118)
2023 Kubota...
