Plump in Grapple on 5030
   / Plump in Grapple on 5030 #1
k4330
poconos pa
Kubota 5030 hst
I just bought a root bucket with a grapple and need to plump it in with a control, I have searched through the post and have not found anything about front hydros, Has anybody done this ? .. Thanks for any info
   / Plump in Grapple on 5030 #2
Well either you have to add a 3rd function valve or if you have rear hydraulic remotes you can run it off one of those and run hoses to the front of the tractor and do it that way.
   / Plump in Grapple on 5030 #3
k4330, I just connected two long hoses one of the rear remotes.
   / Plump in Grapple on 5030 #4
If you have rear remotes, you can do the long hose thing, or you can get a selector/diverter valve and do it right.
Mount the diverter valve on the loader cross member.
Use a switch to select between the curl and grapple.
A true 3rd function will also get the job done and can be mounted on the loader cross member.
   / Plump in Grapple on 5030 #5
Agreed.
   / Plump in Grapple on 5030 #6
I wouldn't say running lines from the rear is "wrong". Its just another option and I'm satisfied with how it works on mine and it was less expensive. If I made a living with it, and that half second to switch hand positions mattered, then maybe I'd justify the diverter valve method. Think it over and go whichever way you'll be happier with.
   / Plump in Grapple on 5030 #7
Here is the diverter to make it simple.
Mount up front.
Add switch to joystick lever.
Bailey International | Mobile Hydraulic Solutions
Use #220934
Default circuit is curl using A-B ports.
With voltage applied, grapple circuit C-D ports is activated.
Thanks.. I like that idea.. I think I have the idea on how to run it but Do you know of a diagram I could look at ? .. Thanks
   / Plump in Grapple on 5030 #9
On my particular tractor the rear remote valve control is so convenient to access (especially after I lengthened it) that I lose no time in reaching it from the loader joystick control. If I had to reach several inches to a side lever, I would rethink my choice. I contend I can operate my control nearly as fast as a divertor or 3rd function button setup, or at least fast enough to not make a difference. But each application will be different.
I don't have rear remotes
2020 Ford F-150 Crew Cab Pickup Truck (A55788)
2020 Ford F-150...
UNUSED 3 STEP - STEP LADDER (A54757)
UNUSED 3 STEP -...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
Case 1083 20ft Corn Head (A55301)
Case 1083 20ft...
UNUSED RAYTREE REDM32 - 32" HYD MULCHER (A54757)
UNUSED RAYTREE...
