Plugging in generator to your house dangerous?
   / Plugging in generator to your house dangerous? #91
I am not clear why you need a grounding rod? Unless I still don’t understand. Totally possible.
Watch this video, Ben is a very smart guy, and i think it will help you understand alot of things. He can explain things much better than i can.
   / Plugging in generator to your house dangerous? #92
"To stabilize the voltage to earth during normal operation." NEC Art 250.4
By NEC code defintion, Ground = Earth
The Canadian Electric code verbage is substantially the same.
I watched that video a few days ago. I guess I thought I understand. But I must not.
if you have a suitable ground connected to the panel that the ground and neutral wires from the generator connect to, why do you need another connected to the generator?
   / Plugging in generator to your house dangerous? #94
Watch it again until you DO understand.
   / Plugging in generator to your house dangerous? #95
Two things you can explain to me with your superior intellect:
1) how is it possible to backfeed power from a generator when MAIN breaker is off.
2) if (according to you, post 49):
"The electrical supply provider's will have some very strict concise rules in place for adding an outsourced power supply. If you are found in abeyance of these rules you will find your only power source will be whatever you can provide. It will not be the electrical supply company."
May be true in some areas, but not here. When power goes out (again...extreme RARE occurrence) all the neighbors start generators, connecting exactly as I do. If what you say holds water then no one for miles around would ever have power again!
A disconnect transfer switch installed by an electrician is not inexpensive, certainly not worth the expense for the rare times we lose power.
Having buildings here on separate circuits I could power the garage only which has bathroom, shower, etc., again...impossible to backfeed incoming power.
The very few times losing power the provider sends a tech door to door making sure generators are off.
You can't make a blanket statement like that since not everyone's situation is the same. Your "facts" are misleading.
Attached document:
The provinces directive on installation of temporary power. Every province in Canada will such regulations built into their Electrical Code.
There is a difference between “Can Do & May Do”
   / Plugging in generator to your house dangerous? #96
You wired the generator in wrong, grounded one of the conductors to earth ground, and back fed thru the neutral. Neutral isn't on a breaker. Just a guess on my part, not electrician.
   / Plugging in generator to your house dangerous? #97
   / Plugging in generator to your house dangerous? #98
In Egon's defense he has been in Nova Scotia a long time, and Canadians have added useful content to this forum for many years.
I get crap because I live in middle of nowhere and see that different world than the suburban members but it takes different views to better understand the world.
   / Plugging in generator to your house dangerous? #99
Why are you posting a Nova Scotia document. We don't live in Canada. Now I'm starting to doubt your superior intellect.
If you noticed the document described how generators should be hooked up and also a little about grounding. These are all basics to the electrical world. Basically just standard procedure.
Your concern over my intellect is of no concern to myself.
   / Plugging in generator to your house dangerous? #100
Well...no...
From my power my transformer secondary is 240 v center tap, so three wires to meter, there to panel. Main breaker disconnects 240v (two 120v 180° out of phase). This center tap is neutral and goes to driven earth ground. Garage has a sub-panel. By having main breaker off there's no incoming power, transformer center tap is grounded at pole, this lead also grounded at main panel and is neutral.
The generator backfeeds from garage to house, cannot backfeed through an open main breaker back to transformer.
2005 INTERNATIONAL DURASTAR 4400 24FT BOX TRUCK WITH LIFT AXLE (A56138)
2005 INTERNATIONAL...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
Metal American Flag Wall Art (A55853)
Metal American...
2018 John Deere 5075E MFWD Tractor (A53485)
2018 John Deere...
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
Honda EM3500S (A55851)
