Plug aerator
/ Plug aerator
Seems like regular cinder block filled with concrete will weight 90 pounds give or take and 12" wide will be 130 pounds.
If I use wide blocks I will get to 500+ pounds, it should be enough for 7 rows of spoons.
I was limited by the frame I wanted to use and also I need to get between rows in vineyard.
/ Plug aerator #12
That should be a pretty good weight for you, waiting for the ground to have the right moisture content is a pain but helps with keeping the tine wear down and getting better penetration.
I'm not far from you, Stafford off 17 right by the county line.
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2014 Dodge Charger (A59231)
2014 Dodge Charger...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2017 Case CX145D (A60462)
2017 Case CX145D...
