plows
/ plows #1
twinstackram
Indiana
international 234
I have a cat. 0 brinly plow that I used on my Honda RT5000,but up graded to a real compact so I could use cat. 1 tools(easier to find than the cat. 0)plus just bought 8 acres.
my ? can I use this on my IH 234 if I change the pins?
/ plows #2
I expect you can. I have several implements that I use with my Cat 1 Kubota but can also use with my old Honda 5518 with Cat 0 hitch if I install the 0 pins facing inward.
If the Cat 0 pins on your blade are installed facing out, all you can do is try the 1 pins- you might have to drill out the mounting holes.
/ plows #3
Another option is to leave the cat o pins and just use the cat 0-to cat 1 bushings. They simply slide on and make the pin the right diameter for the cat 1 sockets. That way you can use it for either application.
Keep in mind that a cat 0 implement is a tad lighter duty, and a cat 1 tractor can make a pretzle out of a cat 0 implement.. so be carefull.
Soundguy
/ plows #4
Soundguy makes a good suggestion I've seen mentioned elsewhere at these web forums. However, as I understand it, the problem for the RT5000 application is that the rear PTO for a Cat 0 accessory turns at 2000 RPM whereas most Cat 1 applications turn a little over 500 RPM.
Therefore, it would seem prudent to slowly engage and throttle up the PTO with a Cat 1 accessory to see IF it can handle the PTO revolution speed being delivered otherwise the Cat 1 accessory could be damaged in the process.
Additionally, the Cat 1 accessory might not get enough torgue at 500+ rpms' to operate properly and/or the RT5000 may stall at the lower end RPM when working at the Cat 1 accessories needed load.
Good luck.
/ plows #5
DO NOT TRY to run the 540 implements above 540 rpm. THIS IS VERY DANGEROUS and will void your warranty.
CAT 0 has nothing to do with PTO speeds.
/ plows #6
</font><font color="blue" class="small">( DO NOT TRY to run the 540 implements above 540 rpm )</font>
Always wanted to see if my tiller wouldn't turn faster, but never had nerve enough to try it; scared it might hurt me and the tiller both. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
SET OF (20) ACE CATTLE PANELS W/ CONNECTING JOINTS (A63569)
SET OF (20) ACE...
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
2011 WESTERN STAR  4900 SB (A63569)
2011 WESTERN STAR...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
