Plowing vs. Blowing
/ Plowing vs. Blowing #1
bobhaybob
New Jersey, Hunterdon Co.
Kubota B7100HSD
I just purchesed a 1993 B7100HSD with mid mower and turf tires . I purchased this tractor primarly to be able to remove the snow from my 300 foot long, steep lane even though I will probably use it more for mowing.
My previous tractor was a Case 195, which after 35 years (16 years in my service) broke an axel. I am currently trying to decide which method of snow removal would be best suted to this tractor. My Case had a 44 inch manual plow which allowed me to scrape the steep part of the lane bare.
What are your thought? Should I get another plow? Should I get a Snow Blower? Does this Tractor have anough PTO power (12hp) to handle a Snow Blower?
Thanks in advance for your opinions.
Bob
/ Plowing vs. Blowing #2
bobhaybob
you like going forwards or backwards?/w3tcompact/icons/smile.gif I've seen a snowblower mounted on the front of a B7100 using the mid-mount PTO. Your bio does not mention what state you are in, so how much snow are we talking? I've kept a 500 ft. driveway in Michigan clean with a B7100 (turf tires)and the rear blade.If there is about 4" or less you can pull the blade forwards, discharging to one side. Above 4" I had to turn the blade around and shove in reverse. You will find a lot of snowblower fans here, even my neighbor loves his, I just thought they're too much $$$ for something that would rarely be needed.I did consider investing in tire chains, if you have a lot of snow or especially on ice, you get real familiar with the traction lock.
regards
Mutt
Thanks for the info. I have updated my profile.
I am not fond of driving backwards on hills especially in the snow, But I am inclined to think that a front mount blower may be over kill, too expensive and hard to find around here. I've located a used front mount blade, which is what I had on my old tractor, so it looks like that's going to be the answer.
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
2012 TEXAS BRAGG COOL DOWN TRAILER (A65643)
2012 TEXAS BRAGG...
MAGNUM LIGHT TOWER (A65643)
MAGNUM LIGHT TOWER...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
(4) BF Goodrich All Terrain Tires (A65563)
(4) BF Goodrich...
