Snow Plowing snow in the dark
   / Plowing snow in the dark #21
williekioti said:
That's a nice setup Vince. Is your FEL blade homemade or a commercial unit?
Its just homemade from an old rear blade I had laying around..
I'm hoping to find a used pickup plow with power angle at a good price I can fix up and modify to fit sometime in the future..
   / Plowing snow in the dark #22
VictorW said:
Well Vince, you should have received your wish. The lake effect dumped 9-10 inches on us here in about 8 hours.
Erie is always hogging all the snow.
We only got a couple inches yesterday and overnight ..
   / Plowing snow in the dark #23
Vince, I have a 6 1/2 foot blade with the rams that I'm working on to mount on my fel arms. I don't have a QA. I need to make the entire bracket to fit the fel arm pins.
My main question is how are you going to power your power angle? I have the rear remotes and was going to run lines forward with another set of QDs. I didn't want to cut into the rear lines with a tee. I was going to just have a set of matching QDs that I could remove when I needed the rear remotes for something else. I was thinking of two short rubber hydraulic hoses attached to steel lines running forward.
Someone here, had Rick Wallace make lines for them if I remember correctly but I can't remember who.
I hope we get a strong NWest wind and send some of this snow your way, although it does make it nice for skiing and snowmobiling.
   / Plowing snow in the dark #24
I think I will use a setup similar to what would be used on a loader to control a grapple.
An electric solinoid/diverter valve setup on the loader.
I,m no hydraulic expert, so I will need to look into it farther when the time comes and figure out how to make it work..
   / Plowing snow in the dark #25
Thanks Vince. I didn't know that there was such a setup like that. I've never seen a grapple, other than pictures, to figure out how it works. That would be a better idea than mine.
I'll try to push the snow your way. We have enough for a while to play in.
   / Plowing snow in the dark #26
Yup, that's my goal for the future as well. I saw an old Fisher beside the road for $69 and almost stopped. May have to go back there, looked like everything was there 'cept what would have been left on the truck.
   / Plowing snow in the dark #27
hello all.....
no snow to speak of in NH (YET!!!!) i know we will get our share.... i just hope it's not in june....
wanted to share a fairly low cost plow setup that i just came accross from Northern Tool..... it's a clamp on (to FEL) snow plow blade that comes in 5' 6' & 7' models.....
i'm not sklled in fabrication like Vince and the others, and i'm getting a little tired of backing up to plow with the rear blade, so this might be the way to go....
here's the info -
Paynes 72in. Clamp-on Push Blade – Model# PFPB72
Clamp blade onto a bucket and use it to push dirt, gravel and debris, or use it for snow removal. Works with tractors and skid loaders. U.S.A.
   / Plowing snow in the dark #28
It's my goal in the coming year to buy a welder and learn how to use it. I hope then to make my own pallet forks and also buy a snow plow and weld it onto a quick attach plate. I have the hydraulic hoses running to the front for my grapple so I should also be able to angle it with my grapple cylinder. I admire the folks on this site who can do their own welding and make it look professional.
   / Plowing snow in the dark #29
OZ,
Do it, i picked up an almost new Millermatic 210 on Craigslist for $800. A Mig w/gas is a relativly easy set up to learn wth(even i can do it!). I bought the GMAW book at the Miller dealer and it covers just about everything you will need to know. You will never regret having a welder around:)
RD
   / Plowing snow in the dark #30
Oleozz, Do you have any info on how your grapple control works or can you point me to a site where I can learn?
A welder is a nice thing to have. The cost for it is made back with the things you do for yourself. Until you get the hang of it, I wouldn't build anything that is crucial. Your first welds aren't usually the strongest. Get a few pieces of scrap steel to practice on. If you know anybody that welds, have them give you a few pointers and maybe run a few beads with them. The book is good but a little personal coaching can do wonders.
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
Avco / New Idea Hayrake (A50515)
Avco / New Idea...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
91013 (A48082)
91013 (A48082)
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
