Snow Plowing snow in the dark
   / Plowing snow in the dark
jimb1724 said:
hello all.....
no snow to speak of in NH (YET!!!!) i know we will get our share.... i just hope it's not in june....
wanted to share a fairly low cost plow setup that i just came accross from Northern Tool..... it's a clamp on (to FEL) snow plow blade that comes in 5' 6' & 7' models.....
i'm not sklled in fabrication like Vince and the others, and i'm getting a little tired of backing up to plow with the rear blade, so this might be the way to go....
here's the info -
Paynes 72in. Clamp-on Push Blade – Model# PFPB72
Clamp blade onto a bucket and use it to push dirt, gravel and debris, or use it for snow removal. Works with tractors and skid loaders. U.S.A.
I would like to see how that works. Keep us posted. Maybe a winter in the future I will invest if you are happy.
   / Plowing snow in the dark #32
Interesting idea, I don't know if I would want it so far ahead of the FEL.
Here is the link to their website. Paynes 72in. Clamp-on Push Blade – Model# PFPB72 |Skid-Steers + Attachments | Northern Tool + Equipment
   / Plowing snow in the dark #34
A local tractor shop makes their own like the one Dmace has in the picture. They do extend a bit out from the bucket and I was also worried with the twisting force on the cutting edge and the bottom of the bucket. They are asking $850 for the six foot model.
   / Plowing snow in the dark #35
DMACE.... that's the issue i am concerned about..... i'll be pushing downhill which should help..... i guess i'll keep searching
I agree. Not so far out.
I was thinking as I used my front bucket to push some packed snow that it would be great if a plow could be attached right to the sides of the bucket with an adjustment like the scraper blade for angle and use the bucket for up and down.
I buy not make these types of things but I am still looking. For a CK20, 54" would be fine...maybe 60"
   / Plowing snow in the dark #37
CBB,
Have you ever seen the set up where they hook a blade on the front of a big loader bucket? I've seen these being used by companies who plow mall parking lots. You could do this with a blade. Weld on some steel to lock it on the cutting edge and then chain it to the bucket. Bad thing is no angle.
Good luck in your hunt.
   / Plowing snow in the dark #38
This is similar to something I'd like to build except I plan on using a mower that extends out from either side of the bucket. The unit would be for mowing out over ditches and banks.
After seeing this picture I may include and adapter in the design to accept a front blade and to allow the mower to extend our from the front of the bucket as well as the original option to hang the mower out past either side of the bucket.
Plans already include a 2 wheeled trailer dolly so that the Mower could be towed behind any tractor ATV etc.
The Mower, Trailer and Trailer wheels all would have several off set positions.
   / Plowing snow in the dark #39
VictorW ...Peak and Peak, wow that is a blast from the past.. Cathedral Prep ski trips in high school many moons ago from Erie....
   / Plowing snow in the dark #40
CBB,
If you are only looking for a 54", I think I saw a JD 54" for a 400 series garden tractor for sale in the classifieds for $250. If it's like the one I have, it comes with angle and lift cylinders, and can be quick attach. It's very well made. Sells new for something close to $1000. Not sure if it could be modified for your CK20. But, thought I'd at least point it out to you. It works so well on my JD425 that I don't even use my Kioti. The little deere is just way more maneuverable in my tight spaces.
UNUSED LANDHONOR LHR-LB9510 LEAF BLOWER (A57193)
UNUSED LANDHONOR...
KENWORTH ROLLBACK TOW TRUCK (A52706)
KENWORTH ROLLBACK...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
UNUSED PABREAK METAL BEAR SHOOTING TARGET (A57193)
UNUSED PABREAK...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
