Plowing and Discing with L4300DT
   / Plowing and Discing with L4300DT #1
JimME
Aroostook County, Maine
Kubota L4300DT
I bought a Pittsburgh Plow 2-14" with auto trip and adjusting lever from Sweet Equipment. I couldn't find anything this small in good shape in northern Maine. The transaction and delivery went without a hitch. Ken Sweet is a gentleman and very knowledgeable. I would buy from him again.
I plowed about an acre today. Here is a pic of the plow. It took some adjusting to get the plow functioning well. The narrow front wheels of my L4300DT required me to side shift/adjust the plow to the left so the first moldboard would have some ground to bite. I ran the left rear tire on a 7-8" cement block and adjusted the 3 point arms until the plow was leveled side to side and front to rear. This plow has a hand lever adjust which changes the direction the plow points. I found that plowing in high range, 2nd gear at about 2,000 rpm turned the sod over nicely. I fought with buried bailing twine (lots of it) which kept binding in the sod and dirt causing it to not release from the plow and create a giant dirtball that I had to stop and remove.
The L4300DT pulled the plow well, but for those questioning a 3-bottom with this sized tractor, I wouldn't do it. Even with loaded rear tires and the loader on for extra weight, this plow feels well matched to the tractor and gave it a good workout. The ground hasn't been turned in many years and was a bit too wet in places. I almost got stuck discing.
Here is a pic of the John Deere disc I bought from Sweet Equipment. It is the old pull or drag type which costs considerably less than a 3 point lift type. In my opinion, it sinks in and cuts better than a 3 pt. lift disc.
A picture showing the interference with the frame for the right coulter and the right 3 pt. arm BEFORE I side shifted the plow to the left. After adjusting the plow to the left, this was no longer a problem.
Starting this morning with the little fellas watching.
Reinforcements ready should I get stuck.
A pic of the bailing twine that kept gumming up the process.
One additional note: If you have rocky ground or ledges you may want to consider an "auto trip" plow if you buy used. I've used a shear pin plow and every time it trips you have to get off the tractor and replace the pin/bolt. The autotrip tripped twice today due to underground ledge/large rocks. All I had to do was backup to reset the plow and I was on my way. Very easy...
   / Plowing and Discing with L4300DT #8
Jim
Thanks for the great post. Excellent photos! I'm about to try my hand plowing next week. I'm borrowing a plow from a friend, and he'll be there to help me out and give tips.
   / Plowing and Discing with L4300DT #9
Thanks Jim and it was a pleasure doing business with you. I dont know how long you have been plowing, but those furrows look as good as I have ever seen! A nice 6 inch well casing with a couple hooks welded on, would make a nice drag for that JD disc harrow and help seal off that sod and speed up the decay process. --Ken Sweet
Sweet Farm Equipment LLC *Over 1000 Pieces new and used equipment*
   / Plowing and Discing with L4300DT #10
Good pic's Jim, glad to see your getting the Kubota dirty /forums/images/graemlins/grin.gif.Looks like it's drying up pretty good in your area.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2001 TOYOTA 7FCGU25 FORKLIFT (A51222)
2001 TOYOTA...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
