Plowing and Discing with L4300DT
   / Plowing and Discing with L4300DT #1
JimME
Aroostook County, Maine
Kubota L4300DT
I bought a Pittsburgh Plow 2-14" with auto trip and adjusting lever from Sweet Equipment. I couldn't find anything this small in good shape in northern Maine. The transaction and delivery went without a hitch. Ken Sweet is a gentleman and very knowledgeable. I would buy from him again.
I plowed about an acre today. Here is a pic of the plow. It took some adjusting to get the plow functioning well. The narrow front wheels of my L4300DT required me to side shift/adjust the plow to the left so the first moldboard would have some ground to bite. I ran the left rear tire on a 7-8" cement block and adjusted the 3 point arms until the plow was leveled side to side and front to rear. This plow has a hand lever adjust which changes the direction the plow points. I found that plowing in high range, 2nd gear at about 2,000 rpm turned the sod over nicely. I fought with buried bailing twine (lots of it) which kept binding in the sod and dirt causing it to not release from the plow and create a giant dirtball that I had to stop and remove.
The L4300DT pulled the plow well, but for those questioning a 3-bottom with this sized tractor, I wouldn't do it. Even with loaded rear tires and the loader on for extra weight, this plow feels well matched to the tractor and gave it a good workout. The ground hasn't been turned in many years and was a bit too wet in places. I almost got stuck discing.
Here is a pic of the John Deere disc I bought from Sweet Equipment. It is the old pull or drag type which costs considerably less than a 3 point lift type. In my opinion, it sinks in and cuts better than a 3 pt. lift disc.
A picture showing the interference with the frame for the right coulter and the right 3 pt. arm BEFORE I side shifted the plow to the left. After adjusting the plow to the left, this was no longer a problem.
Starting this morning with the little fellas watching.
Reinforcements ready should I get stuck.
A pic of the bailing twine that kept gumming up the process.
One additional note: If you have rocky ground or ledges you may want to consider an "auto trip" plow if you buy used. I've used a shear pin plow and every time it trips you have to get off the tractor and replace the pin/bolt. The autotrip tripped twice today due to underground ledge/large rocks. All I had to do was backup to reset the plow and I was on my way. Very easy...
   / Plowing and Discing with L4300DT #8
Jim
Thanks for the great post. Excellent photos! I'm about to try my hand plowing next week. I'm borrowing a plow from a friend, and he'll be there to help me out and give tips.
   / Plowing and Discing with L4300DT #9
Thanks Jim and it was a pleasure doing business with you. I dont know how long you have been plowing, but those furrows look as good as I have ever seen! A nice 6 inch well casing with a couple hooks welded on, would make a nice drag for that JD disc harrow and help seal off that sod and speed up the decay process. --Ken Sweet
Sweet Farm Equipment LLC *Over 1000 Pieces new and used equipment*
   / Plowing and Discing with L4300DT #10
Good pic's Jim, glad to see your getting the Kubota dirty /forums/images/graemlins/grin.gif.Looks like it's drying up pretty good in your area.
2015 INTERNATIONAL PROSTAR 122 SLEEPER (A51219)
2015 INTERNATIONAL...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
