plow work on CK2510
/ plow work on CK2510 #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
100_8081.jpgDo you think this disc plow would work on a CK2510 with a loader.I want to sell this 8N & use the money toward a Kioti CK2510.I don't know what the plow weighs.The CK2510 is rated at 1200lbs lift. Thanks!
/ plow work on CK2510 #2
Which plow or maybe disc harrow are you referring to?
Sorry, pic now added.
/ plow work on CK2510 #4
Weighing it would be best. Or what is the Ford rated to lift? Also try posting this on the Ford forum and/or attachments forum. People there might have an idea of what something like this weighs.:2cents:
Ford 8N rated to lift 800lbs. The Kioti with loader weighs 2800lbs the ford 2400lbs.I think it will work just wanted others onions.
/ plow work on CK2510 #6
I'd think it'd be fine. The ck has quite a bit more lift capacity, as you point out. Even if you go to r4s, the 4wd should compensate and I bet you'd end up with about the same amount of pull. If you go with r1s, you'll have more pull than the 8n, I'd think.
I am going with R4's. Now if I can find the 8N a new home,its off to the dealer!
/ plow work on CK2510 #8
I'd like the 8N, but I'm not ready yet. Where are you and how much? My BIL is Ford crazy. I think he has 2, 1 nicely restored.
/ plow work on CK2510 #9
I have neighbors who keep several tractors, each configured a different attachment, so they don't have to change attachments (at least not often).
/ plow work on CK2510 #11
I have a CK20S which is the CK2510's cousin. I can tell you for sure the CK2510 with loader, will pull about as hard as an 8N. I had both. The only problem you will have is the 3 point hitch. The lift arms on an 8N stick out much further. You would run into problems with a bottom plow with the cutter arm. The CK2510 also does not have as much clearance to lift on the 3 point hitch. I think the better overall match for the 8N is a CK27 or even a CK30. I wish I had bought my CK20S with R1s. The R4s do not have as much pull in the field; however, they do better on hard dirt and pavement.
/ plow work on CK2510 #12
A set of Pat's couplers will extend the 3 pt about 4 inches, they help with my finishing mower to keep the front mower tires from hitting the tractor tires.
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
2016 Kubota RTV X1140 (A65579)
2016 Kubota RTV...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
Pair of 480/80R36 Tires (A65640)
Pair of 480/80R36...
Case TV380 (A62177)
Case TV380 (A62177)
